LOTS of OEM USDM ItR, JDM ItR parts!!! CompTech/KONI/H&R Must Go!!!
FS:/Possible trades:
listed asking prices DO include shipping, however DO NOT include paypal fees but PM me im always open to trades or even best offers if you're buying more then one piece, Email is SDinHD@gmail.com if you want pictures or have offers. sorry just cant load that many pictures
BNIB Eagle 5.430" GsR/ItR connecting Rods, part# CRS5430a3d - $300 shipped
Brand new MSD 8.5mm Ignition wires, Part #32349 - $95 shipped
BNIB MSD SCI-L ignition control box, Part #6320 - $175 shipped
BNIB T1R voltage stabilizer, part# 40000-VP2-P - $75 shipped
Magnecore B18C5/B series Ignition wires - $40 shipped
HardRace DC2/EG/EK Toe adjuster kit #6110 (barely used maybe 2k mi at most) - $75 shipped
Function7 Rear LCA bushings (barely used maybe 2k mi at most) - $40 shipped/set, all 8 halfs
Function7 Rear EndLinks (heim links, with bolts and lock nuts (barely used) - $70 shipped/set both L&R
ApexI B-Pipe (Resonator section, barely used maybe 2k at most) - $175 picked up
Crower 0.5mm oversized flat faced valves, (8) 33.5mm & (8) 28.5mmmm - $60 for 16 valves shipped
Holley Fuel Rail(anodized red) with Holley FPR(silver) Rail retails for $250 and FPR at $200, so half price - $225 shipped
OEM ItR rear camber/upper arms W/ bushings and sleeves (the RTA connecting halfs not the wheel well side) - $60 shipped
OEM ItR Rear trailing arm bushings - $40 shipped
OEM ItR rear toe/compensator arms - $40 shipped
OEM ItR front Lower Control Arms w/ bushings - $80 shipped for both
OEM ItR front compliance bushings - $75 shipped
OEM ItR front Lower control arm bushings - $20 shipped, all 4
OEM '97 Tie rod ends (sterring rack to knuckle) - $40 shipped/set, both L&R with castle nuts
OEM GsR valve springs (dual intake/ItR intake springs) - $100 shipped/set, all 24
OEM '01 ItR Lost Motion Assembly (OEM ItR LMA) - $150 shipped/set, all 8
OEM '01 USDM ItR P73 rods and pistons - $150 shipped/set
OEM ItR oil cooler with hard water line, o rings, thermostat, thermo switch & full housing - $200 shipped
OEM '01 USDM ItR crank pulley - $80 shipped
OEM '97 ItR Brake lines, front and rear - $60 shipped
OEM USDM ItR rear trunk/frame end performance rod - $55 shipped
OEM USDM ItR front lower sway bar w/ oem bushings and end links, 24mm -$140 shipped
OEM ItR TDC sensor, works fine just replaced since it is plastic - $25 shipped
OEM ItR/DC2 timing belt tensioner, bolt and spring - $35 shipped
OEM ItR rear and drivers side motor mounts and L,R rubber mounts - $120 shipped for the 4
OEM DC2 driver side fender liner and engine under cover - $40 picked up for both
OEM USDM drivers side axle - $90 shipped
OEM USDM ItR rear 22mm sway bar bushings - $15 shipped
OEM USDM shift linkage bushing - $15 shipped
OEM ItR/DC2 used thermostat - $15 shipped
OEM ItR/DC2 Oil dipstick - $15 shipped
OEM USDM ItR 1" Brake master cylinder - $120 shipped
OEM ItR Clutch master cylinder - $55 shipped
OEM ItR Clutch slave cylinder - $25 shipped
OEM ItR Clutch hard lines (CMC TO CSC) - $40 shipped
OEM JDM ItR front 25mm sway bar bushings - $15 shipped
OEM '97 USDM ItR CW lip/chin spoiler slightly cracked on front right corner but fixable - $180 picked up
OEM '97-98 ItR CW DC2 Side skirts - $100 picked up
OEM '01 ItR P.P bolts(6) - $15 shipped
OEM '01 ItR Main bolts (10) - $20 shipped
OEM '01 ItR Head Bolts (10) - $40 shipped
OEM '97 USDM ItR Fuel Pump - $60 shipped
OEM '01 USDM ItR Fuel Filter and banjo bolt - $25 shipped
OEM USDM ItR Cat. Conv. (maybe a AFR installed and then re welded?) - $120 shipped
DC Sports JDM 4-1 header (dents) - $120 picked up
CompTech CAI with filter, complete - $250 shipped
ApexI VAFC w/ all harness and manual - $110 shipped
OEM front 6-1/2" speakers and tweeters - $70 shipped
BNIB OEM ball dust boot for 92-01 Integra, 51225-SR0-A01 - $15 shipped
BNIB OEM tie rod boot for 97+Integra and more, 53546-S84-003 - $15 shipped
BNIB OEM GsR Ex. manifold gasket, 18115-P72-003 - $15 shipped
AutoMeter Pro-Comp oil pressure guage, 0-100psi - $20 shipped
OEM IiR PS pump, belt,line and reservoir - $150 picked up
Full OEM ItR AC System w pump/belt/condenser - $450 picked up
Because I've replaced everything on the caR and this is what i am selling? I am well over $20k invested into this car and havent even started the motor build. Please explain where i am making all this 'money'.
all hardware included to mount to the front bumper? I need
