budget build b20V advice/comments
Old Jul 9, 2010 | 07:02 PM
dm23's Avatar
Default budget build b20V advice/comments
want some reviews and comments on the parts purchased for my budget build.
98 itr complete head( cams,valvetrain.intake manifold and tb) gonna be slightly milled
jdm b20b block with b20z pistons (new NPR piston rings)
arp headstuds and arp rod bolts
acl bearing kit(b20b)
new itr oil & water pumps with gates b18c timing belt
new valve seals and block seal kit
blackworks vtec conversion kit
96 itr spec headers with 2.5 inch exhaust
go autoworks oil catch can kit .
hoping for at least 170 whp with 130tq for a fun street motor. also aiming to get the compression up to at least 10:1 or 10.2:1..car is gonna be run on 93 octane. also gonna run a CTR tranny .
what advice and comments do you have ?
thanks
Old Jul 10, 2010 | 09:32 AM
gutted-dx's Avatar
Default Re: budget build b20V advice/comments
Sounds like you'll be right at 170, is that ITR header the cast one?
Old Jul 10, 2010 | 09:53 AM
dm23's Avatar
yup the cast one ...decided to ditch the blackworks kit in favor of the golden eagle..
Old Jul 10, 2010 | 10:03 AM
gutted-dx's Avatar
I'm using the Full-Race kit myself and i've had no problems. Just gotta by the headgasket.
Old Jul 10, 2010 | 01:04 PM
Hatorade's Avatar
very interested in your setup. I am doing the same thing but with an ITR head milled 50 thou and a 96 spec ITR tranny.
post up dynos when you gots them!
Old Jul 10, 2010 | 08:20 PM
dm23's Avatar
more than likely you'll be finished before me ...still in the process of ordering parts ...picked up the catch today ...
looking for some dyno figures for similar set-ups ..most of the guys in the b20 thread are built.
Old Jul 10, 2010 | 09:21 PM
acydphryck's Avatar
i'd run bigger injectors and high capacity fuel pump with that setup...make sure you get enough fuel when you're @ WOT
Old Jul 10, 2010 | 09:27 PM
Hatorade's Avatar
I thought you didn't need to upgrade fuel system if the bottom end stayed stock. can't I just up the fuel pressure with a FPR?
Old Jul 10, 2010 | 10:00 PM
acydphryck's Avatar
you can't just add fuel randomly throughout the entire power band and expect to gain whp throughout...you'll need to get tuned with a stand alone engine management system to manage air/fuel to ensure whp gains
ek_b16
Mar 30, 2010 12:57 AM
97CWITR
25
Dec 29, 2009 08:23 PM
MurdersV8s
15
Feb 12, 2008 04:04 PM
team-savage
26
Oct 25, 2006 08:32 AM
CRVTEC0WNZJ00
21
Mar 6, 2005 12:25 AM
