how do I know if I have the y1 lsd tranny????
Old Sep 15, 2002 | 09:57 AM
Shea-bird's Avatar
New User
Default how do I know if I have the y1 lsd tranny????
I kind of think I do because I use to have a se-r and it had an lsd which whinned and my ef whines....and if I do, is the clutch different than the reg. b16 cable trannies? thanks...
Old Sep 15, 2002 | 10:19 AM
JAMinCiViC's Avatar
Default Re: how do I know if I have the y1 lsd tranny???? (Shea-bird)
It will be stamped with the letters "L S D" near the tranny code label
Old Sep 15, 2002 | 10:26 AM
Mugen Dom's Avatar
Default Re: how do I know if I have the y1 lsd tranny???? (JAMinCiViC)
that is true and if u can see all the way thru ur differential housing thats another way to tell....clutches do not differ
Old Sep 15, 2002 | 11:07 AM
ThatRicerDaniel's Avatar
put the front end up and drive ~ if both tires spin its LSD
Old Sep 15, 2002 | 11:10 AM
Mugen Dom's Avatar
Default Re: how do I know if I have the y1 lsd tranny???? (NitrousDreamz)
uhhhhmmmm no my sohc si trans wil do that if u put it in the air and spin one tire one way and teh other tire goes the same way then u have lsd if it spins back wards then u dont....must be in gear to do this
Old Sep 15, 2002 | 11:48 AM
Shea-bird's Avatar
New User
where is the stamping at? I am gonna go look now...thanks
Old Sep 15, 2002 | 12:16 PM
RuthlessEF-9's Avatar
right above the trans serial code
Old Sep 15, 2002 | 12:20 PM
Shea-bird's Avatar
New User
Default Re: how do I know if I have the y1 lsd tranny???? (D16z6turbs)
where is the serial code??? I went and looked and couldn't find anything....
Old Sep 15, 2002 | 01:14 PM
JAMinCiViC's Avatar
Look to the left of the Engine code. You can't miss it. unless its saturated with dirt and grime
Old Sep 15, 2002 | 02:15 PM
.Ryan's Avatar
Don't Trust Anyone
Old Sep 15, 2002 | 03:14 PM
Shea-bird's Avatar
New User
Default Re: how do I know if I have the y1 lsd tranny???? (SpoonSportsEF7)
well either I am extremely STUPID , or there is no serial # on my tranny... I always thought it was to the left of the engine code but there is nothing there. I can't find a code anywhere on the tranny
Old Sep 15, 2002 | 03:43 PM
dustin's Avatar
If it has no bar through the differential (i.e. you can see straight through) then it's LSD.
Old Sep 15, 2002 | 04:13 PM
chirp2hrd's Avatar
Default Re: how do I know if I have the y1 lsd tranny???? (dustin)
i have lsd but when i looked threw the hole when i took the axles out i saw a gold color rod going threw is that cause the drive shaft is in the way ?
Old Sep 15, 2002 | 08:33 PM
dustin's Avatar
Default Re: how do I know if I have the y1 lsd tranny???? (chirp2hrd)
You don't have an LSD then. I have a JDM Y1 transmission w/ LSD and there is no rod through the differential.
Dustin
Old Sep 15, 2002 | 09:52 PM
rice4life's Avatar
the sticker with serial # must have peeled off. mine came off and i thought my tranny was y1 lsd until i bought clutch for it and it didnt fit, then i found out it was YS1 lsd. the letter "LSD" is tamped in black ink.
Old Sep 16, 2002 | 07:07 AM
Shea-bird's Avatar
New User
Default Re: how do I know if I have the y1 lsd tranny???? (rice4life)
so what clutch do you use for the YS1, because I just ordered a clutch...
Old Sep 16, 2002 | 07:31 PM
rice4life's Avatar
im using clutch master stage3 and aluminum flywheel. you need a clutch for 92-93 teg because the spline is bigger than 90-91 teg. the flywheel is the same for 90-93 teg.
[Modified by rice4life, 8:33 PM 9/16/2002]
racerjohn
Sep 20, 2007 07:43 PM
b16a27
12
Oct 26, 2004 08:25 PM
sambam27
Sep 7, 2003 04:28 PM
gocivicgo
Jun 27, 2003 06:04 PM
