Full Turbo Setup B18 LS VTEC Engine 350whp
Old Jul 9, 2010 | 05:50 AM
MrToasty's Avatar
Default Full Turbo Setup B18 LS VTEC Engine 350whp
Time for me to get rid of the toy and fund my college tuition.
Mileage: 4,500 miles on all of the following:
Stock JDM B16A Head with B18B Block. (LS-VTEC)
• Engine bored .020”/0.5 mm
• Eagle Rods w/ ARP rod bolts
• CP Pistons - 9.0:1 Compression
• ACL Rod and Main Bearings
• Type-R Water and Oil Pump
• ARP Head Studs
• Cometic Head Gasket (Standard thickness)
• Golden Eagle LS/VTEC Conversion Kit
• Slowmotion Triple O-Ring Cam Seal
• Polished Slowmotion Spark Plug Wire Cover
• Competition Clutch and Pressure Plate
• Competition Pro-lite Flywheel (12lb)
• Custom Black w/ Silver Flake Du-Pont Powder Coated Valve Cover w/ Polished Emblems
All listed above for $2,250 w/ clutch/flywheel
Longblock w/out clutch/flywheel- $2,000
Clutch and flywheel combo - $350.00
Engine put out 350 whp and 295 wtq @ 18 psi
Engine was machined (and valve job) by Philips Racing Engines in Grove City and tuned (and partially built) by Corey Parish at Slowmotion Motorsports in Sunbury, OH.
No pings, knocks, oil leaks, oil burning. Engine is a champ!
I have many many pictures of the build, so just ask!
Also have a Seibon Carbon Fiber Hood (OEM Style) for sale - $300
(It has a dime-sized chip in the front edge of it, which could be covered with something, if you wanted to)
Text or call (leave voicemail) at 614-595-6430
or email at mjl44@uakron.edu
Name is Mike
Thanks!
Old Jul 9, 2010 | 05:56 AM
MrToasty's Avatar
Default Re: Full Turbo Setup B18 LS VTEC Engine 350whp
More...
Old Jul 9, 2010 | 07:03 AM
fv8s's Avatar
BUMP
Old Jul 9, 2010 | 10:59 AM
Rikter's Avatar
no price?
Old Jul 12, 2010 | 06:39 AM
MrToasty's Avatar
Whoops! Sorry, looking for $3,999 for it all, including hood and a rear disc conversion.
Also, the truck has been sold.
Old Jul 12, 2010 | 07:42 AM
hondapimp125's Avatar
willing to part the s300?
Old Jul 12, 2010 | 07:53 AM
MrToasty's Avatar
Because the tune is already setup for the engine and turbo, i'd like to keep everything together, unless I don't get any offers. Ask me again in a couple weeks. =/
Old Jul 12, 2010 | 07:56 AM
hrs-parker's Avatar
not to bad of a deal!!glws
Old Jul 12, 2010 | 09:16 AM
JDMInteg96's Avatar
ttt
Old Jul 12, 2010 | 02:48 PM
MrToasty's Avatar
Thanks for the bumps, all. Obviously, this is a good deal, and i'm looking for the buyer that recognizes how much time, effort and money they can save by buying everything at once, rather than the person that buys everything piece by piece over a long span of time (like I did), and spending much much more than 4,000 dollars for a turbo LSVTEC Swap.
Any questions folks, just ask.
Old Jul 12, 2010 | 03:03 PM
jeffy's Avatar
Any interest in trading this setup for a running driving 97 civic sedan 5spd with 116k miles. All original no mods at all!!!???
It's worth a try.
Old Jul 12, 2010 | 05:01 PM
MrToasty's Avatar
I have no use for two civics. Thanks though.
Really the only trades i'd be interested in would be something I could easily get $4,000 out of, or possibly a '07 + Harley (with cash on my end, of course) or maybe a waverunner...
Old Jul 12, 2010 | 05:26 PM
integradc4_rg87's Avatar
bump for you... im doing the same thing and its a PAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 12, 2010 | 06:27 PM
Speed_1's Avatar
You willing to part it out? Just really looking at the long block. LMK PM me.
Old Jul 13, 2010 | 09:49 AM
MrToasty's Avatar
You guys can PM me with whatever price you are willing to offer on the long block or the turbo kit, but let me know exactly what you want, and how much you are willing to pay for it. I probably won't accept the offer, because I'd still really like to sell this as a kit, but you never know...
Old Jul 13, 2010 | 12:15 PM
Dc4beto's Avatar
Would you be willing to sell the turbo kit?
Old Jul 13, 2010 | 05:25 PM
Speed_1's Avatar
PM'd
Old Jul 13, 2010 | 08:00 PM
MrToasty's Avatar
Make me an offer I can't refuse, and ... sure. The offer would have to, of course, compensate for the fact that I'd need to break up a perfect running swap just to part out, though.
Old Jul 15, 2010 | 07:57 AM
MrToasty's Avatar
Bump for a project you can start on Friday and be pushing 350 whp by the following day! C'mon people!
Old Jul 15, 2010 | 11:12 AM
kmeister's Avatar
will you sell all the turbo gear without the motor? if so ill take it, pm me a price for all the gear and the s300 ......and a seperate price for just all the gear without the s300
Old Jul 15, 2010 | 07:21 PM
MrToasty's Avatar
Price for everything (listed below) is still at a standing price of $3,999 cash. However, If you all are interested in taking this thing away from me in chunks, then pricing is...
KEEP IN MIND, PRICING IS JUST MY (IN MY OPINION, VERY) FAIR ESTIMATE OF WHAT THE USED PART IS WORTH AND WOULD SELL FOR ON ITS OWN. PARTS ARE NOT GOING TO BE SOLD INDIVIDUALLY. JUST LONGBLOCK, OR TURBO KIT, OR BOTH.
• Garrett T3/T04B .60A/R Compressor, .48A/R Turbine $300.00
• Stainless Oil Drain Line $25.00
• Lovefab Tubular Log Manifold $200.00
• Hondata S300 w/ Boost Control $550.00
• Hondata Solenoid for Boost Control -
• Tial 38mm Wastegate $200.00
• Large Bar/Plate Front Mount Intercooler (unknown brand) $150.00
• Custom Aluminum Intercooler Piping and High Quality T-Bolt Clamps $50.00
• Custom 2.5” Stainless Steel Down pipe/Flex Pipe/Dump Tube
• 3” Thermal Research & Development Cat-back Exhaust (stainless) $150.00
• Blitz Blow Off Valve $100.00
• Stainless Turbo Oil-Feed Line $15.00
• Precision 780cc injectors w/ resistor pack $200.00
• Walbro 255 LPH Fuel Pump $70.00
• 3-Bar GM MAP Sensor $60.00
• K&N Air Filter $10.00
• B&M Black-Out Water Temp Gauge $30.00
• AEM UEGO Wideband with Gauge $150.00
• Dual Gauge Pod (Around Instrument Cluster) $25.00
• Golden Eagle Vacuum Manifold $50.00
Total: $2,335.00
Your Price for the Turbo kit: $1,800.00
Stock JDM B16A Head with B18B Block. (LS-VTEC) $650.00
• Engine bored .020”/0.5 mm -
• Eagle Rods w/ ARP rod bolts $200.00
• CP Pistons - 9.0:1 Compression $350.00
• ACL Rod and Main Bearings $75.00
• Type-R Water and Oil Pump $75.00
• ARP Head Studs $75.00
• Cometic Head Gasket (Standard thickness) $60.00
• Golden Eagle LS/VTEC Conversion Kit $135.00
• C&R Aluminum Half Radiator $150.00
• Perma-Cool 1650 CFM Fan $100.00
• Slowmotion Triple O-Ring Cam Seal $15.00
• Polished Slowmotion Spark Plug Wire Cover $35.00
• Competition Clutch and Pressure Plate $350.00
• Competition Pro-lite Flywheel (12lb) -
• Custom Black w/ Silver Flake Du-Pont Powder Coated Valve Cover w/ Polished Emblems $75.00
• Distributor OBD2 $65.00
• Intake Manifold/Throttle body/other extras… $50.00
• Labor to put it all together, break in, tune, fluids, swap, etc… $500.00
• Axles $75.00
• Shift Linkage $50.00
Total: $3,085.00
Your Price for the Longblock kit: $2,600.00
• 1994 Integra LS Hydraulic Transmission $300.00
As of right now, I'd just like to sell as a whole complete swap, or in these two individual 'chunks'... please do not ask "How much for one injector... I lost mine" or... "I could really use a waste gate, how much for yours?"
Old Jul 16, 2010 | 12:51 PM
MrToasty's Avatar
Bump!
Old Jul 20, 2010 | 08:20 AM
MrToasty's Avatar
Bump for... nothing being sold yet!
Old Jul 20, 2010 | 06:53 PM
carbon fiber coupe's Avatar
sent you a text..
Old Jul 22, 2010 | 06:56 PM
MrToasty's Avatar
NEW PRICE!
$1800 through paypal gets you the turbo kit. I'll pay shipping.
