HELP...97 acura cl lug stems
what's going on, i am trying to change the lug stems on my 97 acura cl and i am having a little bit of trouble. could someone walk me through or point me in the right direction as to how to take them off please. i have already taken off the brakes and the caliper, what would be the next step. the rotor spins freely but the part that the actual lug stems are pressed in is barely budging. it actual moves with the axle. please help...
I think the 97 cl is similar to the accord if not the same. you'll need to disconnect the lower ball joint and pull the axle out of the hub while you swing the knuckle out. it's really easier if you just disconnect the tie rod and upper ball joint and completely remove the knuckle. it's heavy and it's hard to work with on the car. unbolt the hub from the knuckle and tap it out on the edges if it is stuck. unbolt the rotor from the hub so you can hammer out the wheel studs. tap the new ones in and put it all back together.
