Rear disk brake swap for 91 Civic - Has anyone done this?
Old Sep 15, 2002 | 08:51 AM
Sleeper Sii's Avatar
Default Rear disk brake swap for 91 Civic - Has anyone done this?
I currently have a 91 Civic Si. It has the stock disks on the front and drum brakes in the back.
Has anyone swapped the rear trailing arms off of an Integra to get the disk brakes on the rear?
If so, what parts are needed and what kind of job is it?
Thank you in advance.
Old Sep 15, 2002 | 08:55 AM
LSVTEC96HB's Avatar
Default Re: Rear disk brake swap for 91 Civic - Has anyone done this? (Sleeper Sii)
not sure about the integra rear trailing arms, but I am positive that the rear disc assembly off a '91 CRX SI will fit perfectly. the only other problem is the e-brake cables wont work, you have to use the ones from an integra GS.
good luck
Old Sep 15, 2002 | 10:12 AM
EightOhOne's Avatar
Default Re: Rear disk brake swap for 91 Civic - Has anyone done this? (blown96HB)
go in the ef/crx forum and do a search there....there area lot of these threads for you to check out. you can use the trailing arm assembly from a 90-93 teg and it will bolt right up. Just get the whole trailing arm assembly and E-brake cables from the teg. The biggest pain in the *** on this swap is running the ebrake cables through the grommets at the bottom of the car to go in the cabin. Good luck
Old Sep 15, 2002 | 01:00 PM
Default Re: Rear disk brake swap for 91 Civic - Has anyone done this? (EightOhOne)
Will I be able to use the existing master cylinder?
Is it possible to use a larger one to compensate for the increased slave piston volume?
Old Sep 15, 2002 | 02:15 PM
thejdmkid's Avatar
find a 4dr 91 ex civic they have factory rear discs, very rare....
Old Sep 15, 2002 | 03:44 PM
91vtecripper's Avatar
Default Re: Rear disk brake swap for 91 Civic - Has anyone done this? (thejdmkid)
I just put sir suspension on yesterday but i used the rears of a civic sir and a crx sir proportioning valve. First time doing this by myself, kind of difficult at moments but worth it.
mario_pic
Mar 27, 2008 11:10 PM
LSVTEC96HB
33
Dec 4, 2007 02:47 AM
Big red89
Oct 9, 2007 11:18 AM
bugster
10
Aug 16, 2006 06:19 PM
Sleeper Sii
Mar 29, 2002 07:35 AM
