D Series Parts For Sale
Hey,
89-91 CRX Si D series tranny, shifts great, no shaft play, comes with tranny bracket. $100
D series axles, drivers and passenger, good condition, no axle nuts $50
CRX Hf knuckles with good wheel bearings, drivers and passanger $25 (has small axle id)
Z6 single cam head, needs valve work, no valve cover and vtec noid. $25
D series stock flywheel. good condition $10
89-91 CRX si pm6...? ecu $25
92-95 D series intake manifold and fuel rail $25
D series Crank, needs polished $25
D series pistons, used, on rods, one rod is destroyed set of 4 $25
D series oil pan $10
D series odds and ends and bolts, used water pump, oil pump, etc, $10
Complete D series bottom end rebuild gasket kit, new sealed $25
will also trade for b seires parts for crx b swapped ls. 5097681990, text, email, or please leave a message if you call. Spokane Wa
