HELP B16 with sk2 stage2 cams ticking!
After I installed skunk2 stage 2 cams, sk2 springs and retainers I set the valve clearance to stock but its ticking like there are not adjusted right. Just wanted to know what other people with sk2 stage2s are setting there valve clearance to. Thanks
Did you set the tolerances correctly? It's easier than one thinks to mess that up. Giving S2 a call is your best bet to find out what you should set them at though.
MaaseyRacer
Jul 4, 2004 08:57 PM
