King Engine bearings? Anyone use them? If not what do you use?
Old Jul 7, 2010 | 09:05 AM
Drag4Life723's Avatar
Default King Engine bearings? Anyone use them? If not what do you use?
I have used ACL duraglide and race bearing on about 95% of the engines i have built. I used a set of kings about 5years ago with good luck. With the whole ACL failing at life with the price jump and the intergalactic back order on b18/b20 bearings i need to get some and would like to hear what every one is using out there.
Thanks
Russ
Old Jul 7, 2010 | 09:35 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: King Engine bearings? Anyone use them? If not what do you use?
I used a set of kings in a factory rebuild.
Worked ok.
As far as I know its still driving.
That was 4 years ago
Old Jul 7, 2010 | 11:05 AM
Redline130's Avatar
Clevites have worked well for me so far.
Old Jul 7, 2010 | 11:53 AM
E85B18's Avatar
Why not just order ACL bearings from an online store that has them in stock?
Old Jul 7, 2010 | 12:14 PM
B18c1turboedEK's Avatar
Who carries them? I've been looking and noone carried them in stock I guess.
Old Jul 7, 2010 | 12:20 PM
E85B18's Avatar
http://www.maperformance.com/honda-a...gine-bearings/
Plus Im sure there must be a number of H-T sponsors that have them in stock
Old Jul 7, 2010 | 12:23 PM
Justin Jones's Avatar
King is a really good bearing if you ask me, I used them in my B18C build.
Old Jul 7, 2010 | 12:27 PM
I called and emailed over 60 companies in and out of the US no one has them.
yep!
They dont have them.
Old Jul 7, 2010 | 12:51 PM
E-Town4229's Avatar
are you talking about OEM?
-Roger
Old Jul 7, 2010 | 01:13 PM
nope already checked. I guess everyone drop ships them only.I'm just going too get OEM and be done with it. I can't wait 11weeks
Old Jul 7, 2010 | 01:16 PM
EGhatch87's Avatar
x2
Old Jul 7, 2010 | 01:17 PM
RealStreet's Avatar
Yeah the ACL thing sucks. we do have mains/thrust acl race but are out of the rod bearings for B16 and LS motors. I believe I have a few sets of B18C HX rod bearings too.
ACL Says end of July. I also have the full set of Clevite in stock with the H rod bearing. Been having to use that with the whole ACL fiasco.
Old Jul 7, 2010 | 04:08 PM
-Roger
there duraglide and race bearings like i stated in the OP.
Old Jul 7, 2010 | 04:09 PM
Any of the Outlaw and SFWD guys have any certain bearings you like???
Old Jul 7, 2010 | 06:17 PM
Boosted-EH-804's Avatar
I have used King in my last motor they held up great and are still holding up in a friends chassis
Old Jul 7, 2010 | 06:41 PM
regamaster's Avatar
they do not make them hardened like the ACL bearings are (1925h)
If they would actually have them hardened, they would sell a lot better. For race motors, they are not too good. they cant take a beating especially at high rpm.
Old Jul 7, 2010 | 06:49 PM
non-VTEC's Avatar
king bearings here....making over 400whp with them. no problems. actually the last 3 or 4 engine setups i went thru all used king bearings...never a bearing related failure/problem. they seem to work just fine...they can take the abuse...
Old Jul 7, 2010 | 07:04 PM
I dont know were you got your info but according to king there HP bearings hard just like the ACL Race.
Old Jul 8, 2010 | 06:15 AM
96 GSR-T's Avatar
Contact Laskey Racing I got a full B-Series ACL Bearing set for $100 shipped, cant beat that!
My old motor had King's in it, never had a problem with them.
Old Jul 8, 2010 | 06:56 AM
tony1's Avatar
Why not just use OEM Honda? That's all we use in our motors.
Old Jul 8, 2010 | 10:11 AM
Diller's Avatar
My father used to sell their bearings in the late 90's. He swears by them. He has them on a 800hp 460 that was built ten years ago, has at least four hundred passes on it and still going strong.
Old Jul 8, 2010 | 10:35 AM
turbotypeR@SPEC's Avatar
25 Year Member
Only OEM Honda here! I have used others, but none compare to Honda! Period.
Old Jul 8, 2010 | 11:47 AM
DIABOLIC8's Avatar
OEM bearings are what I hear most people use, I have never heard any bad things with the oem honda bearings.
Old Jul 8, 2010 | 02:08 PM
BubsBoostedEG's Avatar
i use oem in my higher hp car 800whp and clevites in a 400hp sohc both i have had good luck with prefer oem tho, recomend playin with the colors to get proper clearances for high hp if useing oem, good luck
Old Jul 8, 2010 | 03:01 PM
mike93eh2's Avatar
that is what i was thinking.. theyre the best to use in my opinion and the only ones i use in engines i build.
