H22 swap into ek PARTS!! PLUS MUCH MORE
closeeeeeeeeddddddddddddddd to make a new thread
570-369-7568 vinny
block: 4th cyl pistion, piston rings and cyl wall are messed up. car just dumped a lot of smoke and i the spark plug for that cyl was gunked up n wut not. i knew it was done so i stopped drivin it and pulled it all apart.
::reason for this problem: the 4th cyl injector had flow issues . leaned it out and therefore detonation....
Vin# JHMBB615XXC005374
Block is complete. all new belts and its converted to manual tensioner $150!
The heads still fine. just get it planed and the one side cleaned and its ready to b installed.. no issues with head at all!
prelude type S cams with Aem true time cam gears
$400 ! FIRM
Type S cams... the cam marked wit (k) & (0) is the intake came and the other is exhaust
570-369-7568
H ek mounts with all brackets(8kmi) $135
starter $65
alternator with belt,$65 sold
internal coil dizzy with 8kmiles used ngk wires $100 SOLD
shifter box wit both cables,$200
custom axles that need boots,$75
half shaft and SH model prelude atts delete adapter plate $140
7lb fly wheel(8kmi)$125
stage1 clutch(8kmi)$75
96-98 vtec ek converted H harness with anti theft injector harness quick release. $150
8kmi obd2a-0bd1 stepdown$25
H22 hytech headers missin mid pipes MAKE OFFER
570-369-7568 vinny
$400 ! FIRM
570-369-7568
starter $65
do you still have the adapter plate? if not where did you get it?
570-369-7568 vinny
$400 ! FIRM
570-369-7568
starter $65
570-369-7568 vinny
$400 ! FIRM
570-369-7568
starter $65
