twin cooling fans
Old Jul 7, 2010 | 12:38 AM
88MonsterSi's Avatar
Default twin cooling fans
hey guys i just ordered a new aluminum radiator with 2 slim fans for my b16 swap, plugging the one up is simple i know, but what about 2, i dont want it the toast the wireing and anything else for that matter because of to much draw, i was thinking about wiring em in together but im not sure how the relay will take it, any suggestions? thanks.
Old Jul 7, 2010 | 12:57 AM
BenjaminX2's Avatar
Default Re: twin cooling fans
How much amp does the OEM one draw? How much does one aftermarket draw? Muliple times 2, if it's lower then OEM, give it a go on running them parallel. Otherwise, beef up the relay. If it's way out of spec, think about the wiring. You wouldn't want them melting.
Old Jul 7, 2010 | 01:13 PM
well thats what i was thinking but i have know idea what the specs on the oem relay and fans are, and cant find em anywhere.
Old Jul 8, 2010 | 09:23 AM
Dual-500's Avatar
If you have a DVM/DMM use that - splice it into the + line going to the fan. Use amp setting to measure current.
DVM = Digital Volt Meter
DMM = Digital Multi Meter
Same thing.
If you don't have a meter, get one. Not expensive and good to have in toolbox.
One like this from Sears will work fine: Morris 57030 Dmm - and are under $25.00.
Old Jul 8, 2010 | 01:44 PM
hoga113's Avatar
I Had two fan as well, I just plug them on where ever the stock one before, one for the ac, and one connected to the thermostat, but I keep it run all time, been 6 month, no problem.
Charlie Moua
May 10, 2009 05:21 PM
SIred91
May 14, 2008 07:08 PM
Rishiras
Oct 25, 2007 07:06 PM
KOALA YUMMIES
May 28, 2007 10:17 PM
SloCivicHMM
Nov 5, 2003 12:18 PM
