d15b jdm replacement, need to change mount
Old Jul 6, 2010 | 11:20 PM
Mentat Ghola's Avatar
Default d15b jdm replacement, need to change mount
Looks like the driverside mount is different on the JDM model.
Do i need to take off the valve cover, to get the timing cover off?
Does the bottom cover need to come off?
Old Jul 6, 2010 | 11:48 PM
SimpleAznMan's Avatar
Default Re: d15b jdm replacement, need to change mount
what are you talking about? My Si has a D15B and uses the original motor mounts...
Old Jul 7, 2010 | 08:48 AM
Mine is a 99, so its not for the eg chassis, maybe thats why the difference.
Although its going into a 2000 civic
Old Jul 7, 2010 | 10:18 AM
Momentum's Avatar
in for a response...
Old Jul 7, 2010 | 03:50 PM
Driver side lower mount or upper mount..?
Old Jul 7, 2010 | 10:43 PM
upper. Changed it out, had to take off the crank pulley and timing covers.
Since I had to do that I went ahead and changed the timing belt and switched to usdm crank sprocket for Crank Fluctuation sensor fitment. Tomorow its going in the car.
Rishiras
Jan 31, 2010 11:08 PM
lws
Apr 16, 2007 12:40 PM
honda_racing101
Apr 2, 2007 06:34 AM
swappedcx
Dec 24, 2005 04:11 AM
EF4lyfe
Jul 27, 2004 11:05 AM
