eg coupe disc brake convertion help!!!!
i got a 95 coupe ex and i bought a disc brake convertion from a 2001 integra, i just put it on today but some how the e-brake cables wont reach the handle, and double check and all the lines are in place? any one know if the cables are different?????
for a coupe you are gonna need the brake cables from a 2 door dc teg. correct me if im wrong. may be a 4 door. but im almost positive its from the 2 door.
Cool Cool Island Breezes. BOY-EE
If you're using DC cables, they will fit the 95 coupe perfectly. You need to adjust your adjuster till the cables reach. That is you have them in correctly and on the correct sides. There's a left and right cable. The brackets are different.
i just went to the wrecking yard and picked up some rear e-brake cables from a 94 civic si. i thought this was going to fix the problems but same thing the cables are about 1.5 inch shorter same as the 00 2dr integra ones from the convertion? any one know if the four door eg civic are longer or what cables i need to use
1.5''? That's all? Dude, just adjust the adjuster back a little, hook the lines in, and you're done.
Your drum brake cables are going to be longer because of how they route and attach. Seriously. Remove the center console. Adjust your e-brake adjuster back. Attach the cables. Enjoy.
i try ti but is about an inch off, so today i went to the junk yard and picked up some e-brake cables from a 4 door eg ex and FINALLY WORKED PERFECT. they were longer than the integra ones
Darrell Woods
Sep 12, 2016 08:30 PM
dem0nk1d
Oct 29, 2010 01:33 PM
