WTT: 00 Ek Hatch / JDM Type R Swap.
95 integra ls
spruce green primer
INTERIOR
jdm itr steering wheel
itr shifter
jdm itr shift ****
jdm itr climate control
EXTERIOR
spruce green primer
no major dents
jdm itr tail lights
skunk2 coil overs
blox rear camber
asr subframe black
beaks lower tie bar gold
blox lca gold
rota track r white 16x7
new potenza tires
new water pump about 40k
new timing belt about 40k
no smoke
no grinds
typical cam seal leak
97 gsr swap 109K miles(not install)
tranny with 109k miles
act flywheel 9.5 lbs
new oem clutch
no grinds
jdm itr front end(not install)
black housing headlights
new pwjdm smoked side markers
need some work
The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started.
16239_1283561174313_1388629824_827162_3346389_s.jp g
spruce green primer
INTERIOR
itr shifter
jdm itr shift ****
EXTERIOR
spruce green primer
no major dents
jdm itr tail lights
skunk2 coil overs
blox rear camber
asr subframe black
blox lca gold
new potenza tires
no smoke
no grinds
new oem clutch
no grinds
need some work
bonboncito
Southeast (Sales)
19
Aug 22, 2010 01:16 PM
bonboncito
Southeast (Sales)
Jul 7, 2010 07:07 PM
