D16Y8 GAIN HP
what can i do for gain some hp on my single cam vtec? i already got all my gasket new, intake, clean thottle body with manifold. headers and a muffler. some comment and help pls
yeah my bad men, i just want to be a little more quick like basic stuff, non inductions, non nitro, i dont want to f...k my car, so what can you tell me
thats it, go on a diet, and give your car a diet and strip out excess weight..
Since you dont want to do the logical thing and do it the right way, youll need to strip your car to make it lighter. Lighter is faster. But dont think your going to break the sound barrier, you might pick up .2 of a second.
Nitrous is safe as long as YOU dont install it. Spend 600 bucks and do a 65 shot max and then you have your cheap HP solution..
remember that SOHC's take alot of $$$ to have them make power. Your talking about a 1.6 liter engine here.
1st 65 shot
2nd turbo
3rd swap to better engine for your goals.
theres nothing else you can do to your engine besides breaking it open and throwing in high compression pistons, and do the bottom end.
Then you can get a cam and your cam gears and make some decent numbers (still wont touch a GSR or anything of that sort)
1st 65 shot
2nd turbo
supercharger's are good for city driving where reving the engine to a max of 3-4k rpm which is where a supercharger is most useful while highway and racing would use turbo for the power thats at the top end.
I get it but... I wouldn't do it myself. I find it hard to justify as well (unless the goal is VERY instant power for autox or something).
Just make sure that you have someone to consult with about using the stuff. A lot of people use it wrong and make Hondas look bad. Don't add to the statistics!
there is many ways depending what you are planing on going either turbo or all motor. Once you made up your mind you need to set a budget and a goal either choice you make it is all about displacement. So if you got the cash sleve's are the key for a big bore i know vitara has both low and high compresion pistons for single cams. Also invest in a good port polish a good cam and valve train i can go on and on but it is all on your budget. If it was me i would invest in a good cam for now nice way to get hp.
Both of you need to do some research before posting.
we were all a noob at one time..dazed and confused about HP#'s that seems to elude us...
But, once all noobs figure out that going fast costs $$$$, then they figure it out quick.
