DART,Crower,JE,CTR,Eagel,ARP,TODA! NASTY TURBO MOTOR
Make well over 600whp with this Long Block everything is shiny brand spanking new
Again every singel part is brand new! NEVER USED!
4,600 Dollers OR MAKE ME A OFFER! FEEL FREE TO SHOOT ME SOMTHING!!!!!
http://hondatuning.automotive.com/99...ilt/index.html
block 84.50mm bore
*LS crankshaft
*JE pistons 9.3:1 compression,upgraded wrist pins and piston rings
*Eagle H-beam rods
*Moroso 5.5 quart deep sump oil pan with pickup
*Type R oil pump
*Cometic extreme duty head gasket
*ARP head studs
*Golden Eagle head dowels
*B16 head
Ported
*3angle valve job
*Stainless Crower 1mm oversized intake valves, .5mm oversized exhaust valves
*Crower stage 2 turbo cams
*Crower duel vavle springs with titanium retainers
*Crower adjustable cam gears
*TODA timing belt
*CTR crank pulley
*King Motorsports extended intake manifold studs
*Stainless ARP exhaust manifold studs
*Edelbrock Victor X intake manifold with
*Edelbrock throttlebody
*stock fuel rail
*B&M fuel pressure regulator
*RC 750cc saturated fuel injectors
Ill part the long block out!
We can make a deal on the built top end or built bottom end
I have no time to build my car and just sold the peak boost kit
630 347 4107
MAKE A OFFER!
block 84.50mm bore
*LS crankshaft
*Eagle H-beam rods
*Type R oil pump
*ARP head studs
*B16 head
Ported
*3angle valve job
*TODA timing belt
*CTR crank pulley
*stock fuel rail
630 347 4107
MAKE A OFFER!
slick1851
Jul 8, 2010 08:27 AM
slick1851
Jul 6, 2010 01:33 PM
slick1851
May 7, 2010 11:30 AM
