For Sale: Integra Parts
Starting a fresh for sale thread
oh **** handle (has one broken screw cover which can be replaced throug Acura)-$5
under steering column plastic with fuse box cover (missing coin holder, it has two little holes drill in it from a shift light and a few minor scuffs)-$5
negative battery cable-$12 shipped
abs ecu-$20
center console styrofoam-$5
dash vents-$10 shipped (its just a little dusty)
armrest cover with entire beat up center console-$FREE
grey quarter panel window plastics-$20
quarter panel windows-$50 for both
driver side relay panel w/relays (I believe it's the sunroof relays)-$15
abs modulator pump w/lines-$50
power steering rack and pinion with tie rod ends (has torn boot on driver side from sitting in storage and being moved around for a year but knuckle is fine and still has grease on it, and one of the tie rod boots is torn now too from the same thing)-$30
e-brake with boot and handle-$20
gas door-$10
hood release lever-$9 shipped
a/c heater blower motor-$20
evaporator core-$25
front wiper motor-$25
rear wiper motor-$10
auto cruise unit p72 MT-$20 shipped
b-series automatic transmission flexplate w/bolts-$20
hinges-SOLD
horn-SOLD
fender brackets-SOLD
license plate lights-SOLD
clutch fluid reservoir-SOLD
d-series fuel pressure regulator-SOLD
power steering reservoir bracket-SOLD
seatbelt grey bolt covers-SOLD
under hood fuse box with fuses and relays-SOLD
USDM ITR/GSR 24mm front sway bar-SOLD
gas tank/fuel gauge float-SOLD
front bumper reinforcement bar w/styrofoam-SOLD
dome light-SOLD
gas cap-SOLD
rear seat strikers-SOLD
under dash fuse box with fuses-SOLD
gas door release lever-SOLD
a-pillar plastics-SOLD
map light-SOLD
passenger side power window motor and regulator-SOLD
cup holder-SOLD
window fluid reservoir with harness-SOLD
trunk lock-SOLD
door panel lock driver and passenger side black bezels-SOLD
shiftboot cover-SOLD
coolant reservoir-SOLD
cigarette lighter with ashtray-SOLD
hatch plastic (black)-SOLD
dash cluster harness-SOLD
main relay-SOLD
trunk actuator-SOLD
rear bumper reinforcement bar w/styrofoam-SOLD
cluster bezel plastic-SOLD
kick panel plastics-SOLD
driver side dash bolt cover-SOLD
trunk light-SOLD
trunk key cylinder-SOLD
coin holder-SOLD
power door lock control-SOLD
black quarter panel & rear trunk plastics -SOLD
fuel pump assembly-SOLD
passenger airbag-SOLD
LS door panels-SOLD
rearview mirror-SOLD
under radio tray-SOLD
driver side power window motor and regulator-SOLD
power steering high pressure hose-SOLD
bare steering column-SOLD
srs clock spring reel-SOLD
abs relay-SOLD
pedal set-SOLD
gsr spoiler w/ brake light-SOLD
quarter panel moldings-SOLD
stock shifter and **** (**** is a little scuffed up)-SOLD
hood latch w/cable-SOLD
vapor canister/charcoal canister-SOLD
oem 98-01 amber turn signals-SOLD
2000 GSR gauge cluster-SOLD
rear filler panel-SOLD
complete moonroof assembly-SOLD
steering wheel w/airbag-SOLD
The big stuff is for pickup only! PM me if you're interested in anything.
abs ecu-$20
gas door-$10
evaporator core-$25
hinges-SOLD
horn-SOLD
dome light-SOLD
gas cap-SOLD
map light-SOLD
cup holder-SOLD
trunk lock-SOLD
main relay-SOLD
trunk actuator-SOLD
trunk light-SOLD
coin holder-SOLD
LS door panels-SOLD
abs relay-SOLD
pedal set-SOLD
