To spray or not to spray? 2001 Civic Ex
Old Sep 15, 2002 | 12:03 AM
s2k's Avatar
s2k
Default To spray or not to spray? 2001 Civic Ex
I have a 2001 honda civic ex with 7000k on the odometer. I was wondering if it is safe to use nitrous oxide, such as the ZEX kit (dry nitrous) or whatever?
Thank you,
Eddie
Old Sep 15, 2002 | 06:20 AM
VTECTIME's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (VTEC CX)
i pretty sure that Joka is Jokin
Old Sep 15, 2002 | 07:41 AM
hatchdrvr's Avatar
SURE....A good 150 Shot would go nice with that engine
this is the exact kind of BS that we don't need here. Someone is going to think you're serious and put 150 shot on their motor and melt a piston. If you don't have a constructive helpful answer then don't post.
BTW it should be fine to run say a 50-65 shot on your motor without any problems
[Modified by ForceFedEG, 4:42 PM 9/15/2002]
Old Sep 15, 2002 | 08:23 AM
17secondcivic's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (ForceFedEG)
a 50 shot should work just fine just use it moderation, also you should upgrade your plugs, zex makes nice ones for noz
Old Sep 15, 2002 | 08:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Come on man, seriously. Your latest replies haven't been the most constructive or helpful. I know you're an admitted post-***** but please don't post if you cannot add some really helpful info.
Thanks.
Old Sep 15, 2002 | 08:28 AM
Qwikrex's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (17secondcivic)
I suggest running a 50 shot wet kit instead of a dry shot. The fuel is always going to be there and you don't have to worry about an injector clogging and melting a piston. Opt for an NX or NOS 50 shot single fogger wet system. You'll also want to swap your plugs for some that are 2 heat ranges colder(preferably copper plugs, never use platinum). You should also retard your ignition timing 1-2 degrees just as another safety precaution. If you follow these directions, you should have a very safe setup. Good luck on your decision.
Old Sep 15, 2002 | 09:16 AM
delacampos's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex ([VTEC]TL)
zex will not work on the new civics. nor will a NOS dry kit. you must use a wet kit or the venom kit. i have been spraying a NX 75 shot on my 01 civic for over a year already. no problems at all. stock timing too.
Old Sep 15, 2002 | 11:09 AM
IM ALL BOB's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (EK99)
don't the new d16y series motor have a platic Intake manifold I have seen pics of one that basically exploded..hmm let me do a search for it someone did post on HT about
Old Sep 15, 2002 | 12:50 PM
civEX's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (IM ALL BOB)
I have a question too about nitrous; Where would you get a nitrous refill? I'm planning on getting it for my car too.
Old Sep 15, 2002 | 02:52 PM
Briman2021's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (civEX)
One of my friends dads is a dentist, so thats where all my friends get there Nitrous, but ohterwise a welding shop or a speed shop could probably help you. Some jsut wont have the facilities, so you might have to look around.
Be sure to find a place to refill it before you buy the kit, you dont want to find a place 3 hours away that you have to go to once a week.
Good Luck!!
Old Sep 15, 2002 | 03:23 PM
B18C5-EH2's Avatar
Former Moderator
Loved
You should be safe as long as you go with a 75 or 100 shot
What the **** is this?
I swear to GOD I'm so tempted to just delete any and all threads having to do with nitrous or NOS y0! because some people have no clue, yet they think they can still "help" by posting.
Points deducted.
Old Sep 15, 2002 | 04:40 PM
VTECTIME's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (B18C5-EH2)
LOL admin is flippin out
Old Sep 15, 2002 | 06:30 PM
NOSpeed97's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (CivicKilla)
D16's with stock internals should only shoot less than 75-shot. It will survive 75-shot on the street which are usually like 2-block sprints in my area but if you try to get the full 1/4-mile at the track, you really are asking for it (even with minor safety mods like ZEX plugs, retarded ignition timing, 100 octane gas, and Redline Water-Wetter coolant additive). Don't ask me how I know.
Edit: I forgot 2001 Civics were D17, but it's not any tougher than the D16.
[Modified by NOSpeed97, 3:32 AM 9/16/2002]
Old Sep 15, 2002 | 06:31 PM
oldB18EF's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (NOSpeed97)
the 2001 has a D17..not D16
Old Sep 15, 2002 | 07:07 PM
IM ALL BOB's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (WR93EG)
couldn't find the post.. but found these pics of a d17 Intake manifold.. I lack the Shot used.. but I heard he did it out of the hole...
hehe this one is there because I like it..found it the other day
Old Sep 15, 2002 | 07:15 PM
dirtySOHC's's Avatar
my boy blew his D17 on a 65 shot. we just got through rebuilding it. he had colder plugs....but stock fuel pressure and timinig. took about 8 months b4 this happened.
Old Sep 15, 2002 | 07:34 PM
97hb's Avatar
You can only blow your intake manifold if your using a wet shot. A dry shot will not explode in your intake or the manifold. Nitrous doesn't burn, its nitrous and fuel + spark = explosion. I would personally never run a single nozzle wet kit, just a dry (zex)or even better a direct port(witch is a wet kit directly plumbed into the intake manifold .
Old Sep 15, 2002 | 07:41 PM
ELUD THS's Avatar
New User
Default Re: To spray or not to spray? 2001 Civic Ex (97hb)
go with the zex system there are 3 interchangable plugs that come with them. use the 50 shot for safety reasons. also ngk makes a 1 step colder plug as well to use.
Old Sep 15, 2002 | 07:43 PM
InevitableRace's Avatar
spray that bitch...150 shot
Old Sep 15, 2002 | 07:44 PM
CivicVTec's Avatar
u can go for 75 shots the most
dont go anything above 75 Shots
Old Sep 15, 2002 | 09:57 PM
kidkombo's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (allmotrb18c1)
be safe with a 50 shot, it will be enough to hang with most cars, perhaps even beat them. good luck with the decision.
Old Sep 16, 2002 | 01:36 AM
eg_nezay's Avatar
Like somone else said, the ZEX kit will not work on the new civics because of the FPR location(fuel pressure regulator) its located in the back next to the gas tank. Its also electronic not vaccumed and u need a vaccum to run to the Zex box(brain)
If you want to find more info on this cars you should go here
http://www.7thgencivic.com/
Old Sep 16, 2002 | 09:16 AM
azhatch's Avatar
the pics of the manifold blown up was my friend 01 civic lx auto, I was with him. he was using a 50 shot/wet, stomped on it from a stand still and had a n02 backfire, scared the livin poop out of me. I wouldn't do it. He looked all over for a different manifold also, he couldn't find one. Do a search on my user name, probably archived you'll see the thread.
Old Sep 16, 2002 | 09:24 AM
spoonee's Avatar
Default Re: To spray or not to spray? 2001 Civic Ex (socalcivic)
I would'nt do it........nitrous ........
Old Sep 16, 2002 | 10:25 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: To spray or not to spray? 2001 Civic Ex (spoonee)
One more ridiculous post about some crazy-*** shot and this ones on lock down.
