Whats better for n/a running lean or rich
Old Sep 14, 2002 | 11:58 PM
IgniteTeg's Avatar
Default Whats better for n/a running lean or rich
Whats better to run if your N/A is it better to run lean? Or is it better to run rich??? Please explain why its better to run that choice that you choose. Thanks.
Old Sep 15, 2002 | 12:11 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Whats better for n/a running lean or rich (IgniteTeg)
Rich= bad gas mileage
Lean= boom
You want a proper balance.
Old Sep 15, 2002 | 12:26 AM
IgniteTeg's Avatar
Default Re: Whats better for n/a running lean or rich (ActiveAero Ninja Edition)
hmmm yeh thats hard. So whats other pro and cons to runing rich???
Old Sep 15, 2002 | 12:35 AM
Westrock2000's Avatar
Pros: Burns cooler, less oxygen level --> less complete burn --> less heat
Much the way a lighter burns yellow and a cutting torch is blue or white
The cooler burn also means less chance of pinging
Cons: Pretty much just that you'll lose horsepower from running richer, eventually you can reach a point that the fuel actually "washes" the cylinder walls and removes the oil, which is bad, and its an extreme case. Lot more exhaust pollution and deposit alot more carbon on your engine parts and even unburnt fuel in your cat.
Old Sep 15, 2002 | 12:37 AM
IgniteTeg's Avatar
Default Re: Whats better for n/a running lean or rich (Westrock2000)
ahhhhhh i see...Now how bout pros can cons to runing lean beside pingin or detonating or knocking whatever you wana call it...
Old Sep 15, 2002 | 04:26 AM
BigMoose's Avatar
Here is a thumbnail sketch that I posted a bit ago:
OK here is a litter primer.......but I hate giving tuning numbers..cause YMMV.
14.7 is mandatory for emissions with a 3-way catalyst. That is the catalyst that oxidizes CO and Hydrocarbons and reduces NOx. It will have an O2 sensor before and after. 14.7 Air/Fuel ratio is what every engine (except the lean burn ones...which are currently rare) runs during closed loop ECM control.
15.2 ish ... which is lean ... is tolerable on a stock motor driven by a little ol person, and will result in the best MPG. Just don't push it or lug it. HC and CO emissions are down, but NOx is up with this tuning arrangement.
12.9 ish to 12.2 ish is where you should find best power NA. To get closer you need a dyno and specific experience with the setup. Richer is safer against detonation. 12.5 ish is probably a good starting place.
If you can let it run closed loop in daily driving at 14.7 A/F with a cat, your kids lungs will appreciate it in the years to come. These engines really dump a lot of smog causing baddies when run rich.
Regards,
BigMoose
Old Sep 15, 2002 | 04:42 AM
IgniteTeg's Avatar
Default Re: Whats better for n/a running lean or rich (BigMoose)
haha cool nice explaination Thanks a lot. Anyone else?
wc4123
Engine Management and Tuning
Jul 1, 2009 07:44 AM
zirac50
Mar 23, 2007 10:28 PM
IgniteTeg
Sep 15, 2002 11:12 PM
hoya_10fintec
Jun 3, 2002 01:56 AM
Dokta
Feb 23, 2002 07:37 PM
