WIRING
Old Jul 5, 2010 | 07:48 PM
ef9bseries's Avatar
Default WIRING
do i need a jumper harness and where do i get a jumper harnes for my 89 ef b-series swap??
Old Jul 5, 2010 | 07:57 PM
crx_si-r's Avatar
Default Re: WIRING
No, use your stock harness as long as it's set up for mpfi (4 injectors).
Old Jul 5, 2010 | 09:01 PM
D16SiHatch's Avatar
Default Re: WIRING
he's going to need a jumper harness if he needs to run an obd1 ecu.
op: you can get jumper harnesses from numerous websites, including eBay. i recommend rywire myself though. i got mine through them and it's a great product.
http://rywire.com/store/-c-27_38.htm...12efa858f7b166
if you are running an ls though for example then you do not need to convert to obd1. you can run it with an obd0 pr4.
DA john
15
Mar 23, 2013 12:45 PM
DA john
Nov 10, 2011 10:36 AM
HtC_SiR
May 26, 2004 12:11 PM
ABK
May 4, 2004 08:19 PM
91hatch_on17's
Sep 2, 2003 08:27 PM
