Suspension & Brakes Theory, alignment, spring rates....
Figure this one out...
Old Jul 4, 2010 | 04:55 PM
Trk2112's Avatar
Default Figure this one out...
My abs light is on 95% of the time and iv replaced sensors, relays all kinds of stuff but it never went away so I just figured as long as I don't slam on the brakes they wont lock up w/e but the past couple weeks iv noticed that when the light is OFF and everything should be working fine the car pulls to the right when I brake and when I push the clutch to stop the rpms drop likes its ganna stall and idles rough at about 500 rpms?? Anyone ever heard of this?
Old Jul 5, 2010 | 07:51 AM
DOM@SPREENHONDA's Avatar
Default Re: Figure this one out...
check your calipers, might be sticking
Old Jul 5, 2010 | 09:09 AM
Trk2112's Avatar
Well I just replaced the passenger caliper. I'll change the driver side too but would the caliper have anything to do with abs light? And the low rpms, it almost sounds like a vacuum leak maybe when the light comes on it shuts the abs pump?
Old Jul 5, 2010 | 02:58 PM
Yeah i was gonna mention that the idle problem is probley a vacuum leak a stuck caliper can very well cause a abs light pop the hood and run the car, not too hot so the fan isn't running do you hear any hissing?? sounds like 2 seperate problems. Good luck buddy
Old Jul 5, 2010 | 03:29 PM
Trk2112's Avatar
No I don't hear any vacuum leaks under the hood, I'm ganna replace the driver caliper tomorrow and see wat that does. Maybe the low idle is a different problem but it's pretty constant when the light is off. I can tell wat kinda ride it's ganna be by my abs light lol
Old Jul 5, 2010 | 03:55 PM
HAHA I KNOW ALL ABOUT THAT. GOOD LUCK
raene
May 30, 2013 03:13 AM
OBDII Integra
Dec 3, 2009 10:14 AM
95si_v-tec
Sep 21, 2007 12:01 PM
machinehead
Dec 24, 2003 12:27 AM
oioioi
Oct 11, 2002 02:47 PM
