Victor X,Fidanza,Full Race,Sparco,JDM ITR,OEM Honda,Eagle,Profec B,+MORE!
Contact: PM here
Price:$various.Shipping not included.
PICS BELOW LISTINGS
-Fidanza flywheel surface kit.Replacement friction plate,screws and locknuts.Everything you need to make your flywheel like new.B series,but should fit other applications of their products.Part number is in the pic for cross reference purposes.
$30
-Full Race Honda Prostreet oil drain kit.BRAND NEW.
$50
-Eagle rods,B18C1.BRAND NEW!
$250
-Autometer gauges/pods.
SOLD: 2-5/8" Boost gauge
$35: 2-1/16" A/F gauge
$25: OEM A-pillar,with pods attached,dyed black.Couple scratches in dye as seen in pic,but overall very good shape.92-95 Civic coupe/hatch.
-Greddy Profec BII.All parts and manual included
$225
-F1 stage 1 clutch.B series hydro.Includes unused throwout and pilot bearings,alignment tool,instructions.I installed this on my new NA engine,and it's just not up to handling 200WHP.I broke it in for 500 miles,and the first time I got on it after that,it slipped at the top of 3rd gear.I drove the car easy until I got the new,heavier clutch in(so it has about 550 mles total on it).You can see some hot spots on the PP,but it's overall in good shape.Should be fine in a street car with a lower HP B engine(stock Non-VTEC,etc).
$45
-Clutch Specialties dual diaphragm pressure plate with sprung brass puck clutch.B series hydro.I ran this clutch for less than 3k miles on my low boost setup,with the intention of using it on my new engine,but I never completed it.CS doesn't really have stages or anything,as they build each clutch to what you need.I told them I needed a clutch for street/strip use in a 500WHP car on slicks,and this is what they sent.Worked great on the street,very driveable.
$225
-Clutchmasters stage 3 Pressure Plate.B series hydro.Has friction surface has some scoring.Would be good for some extra holding power over a stock PP.
$25
-Tuner Toys oil take off block.For back of block to get oil feed.BRAND NEW!
$20
-Neuspeed front trut bar,92-95 Civic.
$50
-Grounding kit.Splitfire.It came off my JDM R engine,straight from the importer,so it's JDM!!11
$20
JDM ITR 98+ parts:
-Alternator
$100
-A/C mount
$35
-P/S pump,includes mounts
$40
-Intake arm
$25
-Coolant line kit for GT turbo.These are the fittings and line you’ll need to build a coolant line kit for a GT turbo. 7’ of -6 line,and the necessary fittings to connect to the turbo and terminate to wherever on your engine you pick up and return coolant.You’ll just need two fittings to plumb in to whatever source you choose.Paid $136 total.Brand new.
$60
-Momo steering wheel adapter hub for 92-95 Civic,94-01 Integra.Includes horn sweeper arm and rubber cover boot.
$45 for Momo hub
-1995 US B18C1 block and crank.Block has been .5mm overbored and honed,decked,align honed crank journals and hot tanked.Includes brand new Golden Eagle HD main studs(brand new,only used for align-honing).100% Ready for assembly.In the pics,there is some light surface rust visible where the block has set for a few months.This is completely superficial,and will rub off with machine oil.
Crank has not been touched yet.Could be used as-is or polished.Journals are in excellent shape,engine had 120k miles on it,and ran fine until tear down(this was going to be my new turbo engine,but I lost interest).
*note*-I left the block and crank at the shop,as I really don't have room for them here at the house.I will be back at the shop on 7/11,and can ship on 7/12.
$SOLD!!!!! for both.
-Vibrant B series timing belt tensioner.BRAND NEW!
SOLD!!!!
-B series OEM VTEC bottom end gasket kit.BRAND NEW! PN:06111-PR4-030
SOLD!!!
-'98 JDM ITR throttle body.Perfect shape.TPS has a very small chip on the plug,as seen in the pic,but does not affect the function.
SOLD!!!
-Edelbrock Victor X manifold.B18C1.Perfect condition other than greasy fingerprints from removal.
SOLD!!!
-22 tooth OEM water pump.30k miles
SOLD!!
-Fidanza B series hydro aluminum flywheel.Could stand to be resurfaced.Has a small groove just outside the mounting bolts from where a disc spring came out.Doesn't affect operation.
SOLD!!!
-ITR OEM oil pump.BRAND NEW! PN:15100-P72-A01
SOLD!!
-Tekniq quick release
SOLD!!!!
-Sparco Flash5 wheel
SOLD!!!
-4-1 header.includes lower shield,although it's kind of banged up.lower bracket for the behind the oilpan attachment is cut off.No dents of damage to the header tubes or flanges.Includes donut gasket.
SOLD!!!
-B series OEM VTEC head gasket.BRAND NEW! PN:12251-P30-014
SOLD!!!
-Golden Eagle HD head stud kit,B series VTEC.BRAND NEW!
SOLD!!!
-Full Race Prostreet manifold.B series,T3 flange,V-band gate flange.From the original run of the robot welded series.Perfect condition.
SOLD!!!!!
-OEM ITR valvesprings.Complete set of inner and outer for intake and exhaust.BRAND NEW.
SOLD!!!!!!
-Mahle pistons for B18C1, .5mm over. 9:1 compression.BRAND NEW.All specs can be found on the pic of the box.
SOLD!!!!!
-Tial 44mm wastegate
SOLD!!!!!
-Full Race PWR backdoor intercooler.20"x8"x3" core.Flanged for Tial 50mm BOV.
SOLD!!!!!!!
-Tial 50mm BOV
SOLD!!!!!!
-Garrett GT35r turbo. .70A/R, 4" anti-surge inlet,3" V-band exhaust outlet.
SOLD!!!!!!
-RC 750cc High Impedence injectors.
SOLD!!!!!
-AEM EMS. PN:30-1040 OBDI Honda.
SOLD!!!!!
-2.75"-3" Stainless T-bolt clamps.total of 8.
SOLD!!
-Lenso VPD drag wheels.13"x7.5" +25mm offset.4x100mm.Gold color.24.5"x8" MT slicks. 12 1/8th mile passes on the setup.Perfect condition,except for one knick on a lip and a 2" scratch in the lip paint(see pics).
I Will Not separate the wheels and tires.
SOLD!!!!!
Autometer
Profec
JDM ITR parts
Clutch SPecialties
Fidanza flywheel
Clutchmaster PP
F1 clutch
Eagle rods
Oil T fitting
Neuspeed bar
Ground block
MOMO hub
Full Race Drain kit
Fidanza surface kit
AN coolant lines
Contact: PM here
PICS BELOW LISTINGS
$30
$50
$250
$225
$45
$225
$25
$20
$50
$20
JDM ITR 98+ parts:
-Alternator
$100
-A/C mount
$35
$40
-Intake arm
$25
$60
$45 for Momo hub
SOLD!!!!
SOLD!!!
SOLD!!!
SOLD!!!
SOLD!!
SOLD!!!
SOLD!!
SOLD!!!!
SOLD!!!
SOLD!!!
SOLD!!!
SOLD!!!
SOLD!!!!!
SOLD!!!!!!
SOLD!!!!!
SOLD!!!!!
SOLD!!!!!!!
-Tial 50mm BOV
SOLD!!!!!!
SOLD!!!!!!
SOLD!!!!!
SOLD!!!!!
SOLD!!
SOLD!!!!!
Autometer
Profec
JDM ITR parts
Clutch SPecialties
Fidanza flywheel
Clutchmaster PP
F1 clutch
Eagle rods
Oil T fitting
Neuspeed bar
Ground block
MOMO hub
Full Race Drain kit
Fidanza surface kit
AN coolant lines
Can you do any better on the new oem itr oil pump? i have seen brand new oem itr pumps selling on here for 85 bucks. If you do it for 85 i will buy it from you.
$250
--- How did the pedal feel? As in stiffness? Where did it grab when letting it out? What is this set up comparable to... as in another brand ie. ACT...
$250
$250
$250
how about compared to stock lol...
i just picked up my car and it has some booty clutch set up in it... and i can't stand it. it feels as if there is no pedal at all.. and it grabs at the top... i had to adjust it down... but now i have a floppy pedal...
Off the top of my head,I believe an ITR stock pressure plate is 1900lbs.This pressure plate is rated at 3900lbs.I wish I knew the pressure weight of some other aftermarket clutches for comparison.It doesn't feel twice as heavy as a stock clutch though-like I said,slightly heavier than most aftermarket "heavy duty" pressure plates.
