Correct Tranny Info....PLEASE
I am new to H/F engines. I have a JDM Accord Sir-T. It of course has an F20B with the T2T4 trans.
I want to run the M Factory final drive with a longer fifth gear.
Two questions:
What is the CORRECT 5th gear ratio of this trans.?
Are F (single cam) gears and H series gears interchangeable?
Thanx
Two questions:
Thanx
thanx my man.
i actually saw this chart.
however, i have also seen info stating that the T2T4 has a .812 fifth gear. that is why i emphasized that i wanted correct infomation.
what is the source of this chart?
what about the compatibility between H and F trannys??
any help is greatly appreciated.
PirateMcFred,
I decided to use the M Factory calculator to check my 5th gear. However, I am going to use speed. That way I will be able to see the difference in RPM rather than speed.
The reason that I thought the H and F 5th gears were compatible is because they share some of the same ratios for their respective fifth gear.
Thanx for the input.
bnmm
Transmission & Drivetrain
Apr 28, 2012 12:28 AM
