Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost?
Old Sep 14, 2002 | 08:58 PM
slwazgsr's Avatar
Default Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost?
Ok,
I haven't had the kit on for more than a week and I haven't even driven the car when it ran perfect the first 3 days.
I got my Greddy Kit for my 96 GSR installed and while the mechanic and others were "testing" out the car, it ran perfect no hesitation or anything.
The first couple times I got on it, I blew off some pipes so I really never got a chance to drive it because I had to drop the bitch off to get her kit put on.
I picked her up today, and man, something is not right. Symptoms are as followed:
When I floor it, it seems to "bog" down and the car stutters or hesistates right after it passes 5 psi or gets between 4200 and 6000 RPM's
I am running everything that came with the kit
the fuel part of my set-up includes,
Gredddy 310 injectors
Greddy Blue Box
Stock everthing else
I'm not boosting past the recommended 7 psi, what's wrong?
me and another turbo buddy tried another fuel set-up today and it worked "better", we just used his Vortech FMU and it ran fine but a little rich and it slowed down tremendously at the higher RPM's
Turbos are a pain in my ***!
[Modified by xdsmguy, 6:00 AM 9/15/2002]
Old Sep 14, 2002 | 09:13 PM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (xdsmguy)
Re-check the wire connections from the blue box to the ecu. Make sure none of the wires were installed in reverse!
Old Sep 14, 2002 | 09:18 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (DB8GSR)
Get it dyno tunned, maybe that your getting a lil to much fuel or maybe timmings off. Check wiring and vac. sources. The dyno tune will help alot
Blaze
Old Sep 14, 2002 | 09:24 PM
slwazgsr's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (Blaze45)
Oh yeah,
Here's a funny part of my turbo install
When I bought the injectors, the person whom sold it to me told me that I had to buy some GSR clips from a 94-95 OBD1 system
I have a 96 Obd2 system, but the clips bolted right in, No questions asked maybe that's a reason?
Yet, I don't understand why it ran GREAT for two days and than bam!, runs like **** when I floor it, but when I slowly step on the gas, it boosts up fine!
Mick
Old Sep 14, 2002 | 09:53 PM
downpipe's Avatar
i personally had problems with my first blue box. it woudl bog and stutter at exactly 1800 and then again at abour 2600 rpm, then be fine. i finally got greddy to send me another blue box. problem solved. i would check everythign else first, but it may in fact be the blue box.
Old Sep 14, 2002 | 10:37 PM
madman604's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (downpipe)
u need more fuel. a pump. worked for me
i had the same symptoms gradual gas gave more boost, longer. flooring resulted in bogging.
[Modified by Turbo E, 11:40 PM 9/14/2002]
Old Sep 15, 2002 | 07:42 PM
slwazgsr's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (Turbo E)
Well
I'll call Greddy and see what they say
However, we tried an experiment today, We took off the blue box and jumped a wire, and just ran a 12:1 vortech FMU, VOILA!! no more problems
However, if I run the FMU set-up, I will need ..................... ?
what ration FMU? 12:1 or 10:1
Missing Link?
Inline or Intank fuel pump?
Let me know guys.
Thanks
Old Sep 15, 2002 | 07:51 PM
CzanSOHC's Avatar
I say 10:1 w/ 310cc's
Missing link = yes
Inline pump.
Old Sep 15, 2002 | 08:36 PM
ELUD THS's Avatar
New User
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (CzanSOHC)
agree 10:1 is fine with 310cc which you can get from a prelude.
Old Sep 15, 2002 | 11:14 PM
ion_four's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (ELUD THS)
I think he has the 310's already, but you will need the inline pump.
Old Sep 16, 2002 | 02:35 PM
slwazgsr's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (ion_four)
Damn
So I will need the
Inline pump
missing Link
10:1 FMU
Damn might as well go with the new SBC, with my 450;s opinions?
Old Sep 16, 2002 | 04:31 PM
turbod16y8's Avatar
so you're saying when u took off the fmu car ran better? if thats true then car boggs at high rpm becuase of too much fuel. get a fpr and turn it down some. and make sure your plugs are gapped at .030-.034. i had the same problem and it was too much fuel and it bogged. hope that helps you.
Old Sep 16, 2002 | 06:25 PM
slwazgsr's Avatar
Default Re: Why does my Greddy Kit hesistate between 4-6 RPM, and right after 5 psi of boost? (turbod16y8)
nah,
the car ran better WITH the fmu
it runs bad with the blue box set-up
MIck
Old Sep 16, 2002 | 06:33 PM
CzanSOHC's Avatar
a friend had the same problem w/ his blue box...all he did was buy a fuel pump and that fixed it. So i sat just buy a pump and use it with the blue box, and if doesn't help, just get the FMU and missing link. Good luck.
-Chad
Old Sep 16, 2002 | 09:23 PM
slwazgsr's Avatar
I'm just curious that if I"m running too rich, and the box is dumping TOO much fuel than why would getting a higher flowing inline pump help the situation? Just wondering, but thanks for the input.
mick
cdscivic
Oct 16, 2014 02:17 PM
mike93eh
Nov 19, 2005 02:58 PM
112480
Apr 23, 2003 03:13 AM
Bert
Nov 26, 2001 07:01 PM
