Fuel issue good bad ok?
Hey guys going to look at this hatch Wed. Low miles a little rust on the quarters plan to fix those..Auto everything good from whats listed. But when you fill the fuel tank up all the way it will leak only filled max though...Would it be bad o-rings on the filler neck and fuel pump? Or no?
The hose that connects the filler neck to the tank might be loose or rotted. Possible bad seal where the pump or sender goes. Its anybody's guess. Get it in the air on a rack before you buy it.
xwhitchx
Dec 1, 2009 02:24 PM
90civichbsi
Aug 14, 2006 10:51 AM
turbologist
Oct 7, 2003 06:00 PM
