FS OBD1 JRSC GSR Swap
Ok guys willing to take $2700 obo for everything I deliver to Dallas because I'm going for a week leaving Sunday aug 15th will also lower price for parts I need for 92-95 hatch looking for function 7 lca's, nice door panels (black) rear interior panels, eg headlights (oem) also front bumper. Lmk guys
Hey guys I have an OBD1 JRSC GSR. The Overall condtion of motor is pretty good. I am Going to start building a turbo B16 motor. The engine runs excellent. I purchased the car about 9 months ago it came with everything i only added the type r valve cover and have some racing motor mounts i have not installed. What the guy told me when i bought the car the engine was rebuilt about 38,000 miles when purchased which would now put it between 42-46k. The head has skunk2 cam gears he said internals also but i forgot to check when i changed the valve cover. Also i was told it has stock pistons, rods and B20 crank not sure if he meant crankshaft or crankpulley. Has exedy stage 3 clutch i cant really tell what type of injectors but they are probably aftermarket cause its not the stock injector connector. The only bads about the engine is after you do alot of high reving the bottom end has a ticking but stops and only does it sometimes. The car dont burn oil unless you do alot of high reving which is pretty normal. The car is boosting 9 psi According to the aem boost gauge but the sensor went out. Also one tranny bolt hole was stripped out. The swap will consist of Engine, Tranny, ECU p72 chipped, harness, racing mounts, Shift linkages, JSRC, FMU. THe only thing it will not come with is Headers and radiator will throw in radiator for thr right price. The motor is currently in my car and will pull when sold. Anyone is welcome to test drive and see how it runs. Depending on ur location i Will ship in myself for above price OBO. I can throw in a set of Beat up set of dc headers which still work just pretty beat up. Motor located in Amarillo, Tx.
TheThiefTheKnife'NTheGun
Mar 11, 2009 12:17 PM
dingusjt
Jun 11, 2003 08:59 AM
