Honda CR-V & Element 2WD & 4WD Element & CR-V
97 CRV head problems
Old Jul 2, 2010 | 06:23 PM
Davey12678's Avatar
Icon2 97 CRV head problems
I have a burnt valve on my CRV and was wondering if I could use a LS head on the B20 block instead of stock? Would this solve the valve adjustment ever 30k? Pretty sure I could use the LS head would I run into any problems?
Thanks Dave
Old Jul 3, 2010 | 08:52 AM
www.megameet.org's Avatar
Default Re: 97 CRV head problems
yes, you can, and yes, you wouldnt have to do the valve adjustments as much.
Old Jul 3, 2010 | 08:54 AM
HAMOTORSPORTS's Avatar
Yeah, the LS head fits just fine... The CRV are very common to have this problem (in case you weren't aware of this yet ) I'd still suggest a valve adjustment every 30k though. Your factory CRV service manual suggests adjustments every 30k, but the info has been updated if you contact your Honda dealer... They now recommend valve adjustments on the CRV every 15k
Old Jul 3, 2010 | 10:45 AM
Duane_in_Japan's Avatar
By looking at the MAP sensor voltage feedback to the ECU, you can pretty much tell if you need a valve adjustment, if idle and timing are correct, and engine seems to run properly, you should have just a touch under 1V DC going back to the ECU, anything away from there, I would pop the cover and do a quick inspection. There may be a variation to this depending on your altitude.
Old Jul 3, 2010 | 08:36 PM
Davey12678's Avatar
Thanks for the replies I am going to start shopping for a head
cbabyby
Aug 21, 2010 12:09 PM
msncml386
Apr 29, 2009 11:01 AM
mrDFWmechanic
Oct 17, 2004 01:01 AM
all motor b20b
Sep 17, 2004 08:50 PM
