Baseline dyno inside,thoughts/advice request...
Old Jul 2, 2010 | 04:45 PM
$amGD3's Avatar
Swaggylicious
Default Baseline dyno inside,thoughts/advice request...
Hey guys, got a few pulls on the dyno the other day.
'00 B16a2
MemoryFab whale ***** intake
new stock NGK iridium plugs and blue wires
'01 spec ITR intake and exhaust cam
DC 4-2-1 header (2.31")
Megan resonated test pipe
Greddy Ti-C catback exhaust
untuned whatsoever on stock P2T ECU
What do you guys think my next step should be? Should I be dissapointed with these numbers?
Old Jul 2, 2010 | 05:04 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Baseline dyno inside,thoughts/advice request...
considering those numbers are untuned and uncorrected, they look about right. Your actual power is less than indicated here. If you want your engine to last and make more power, your next step should be some sort of tuning system like Neptune, Hondata etc.
Old Jul 2, 2010 | 05:09 PM
$amGD3's Avatar
Swaggylicious
That is my next move, should i move it to the tuning forum or can i ask questions here?
I'm not sure what program to use, what would be the best bang for the buck? I know alot of people say s300 but honestly, all of the parts on this motor combined cost less than an s300
Old Jul 2, 2010 | 05:20 PM
00Red_SiR's Avatar
All Motor Mentor
I would see what your tuner likes but many people seem to like Crome for inexpensive tuning. You could aways look in the tuning section and talk to a couple forum sponsers about your options. But like I already said, the tuner you use usually determines what's best to go with since he's the one who will be doing all the tuning.
Old Jul 2, 2010 | 05:24 PM
neverstop's Avatar
I just went with Chrome, they basically all put out the same whp but hondata has tuning per gear and a bunch of boost and nitrous functionality. Chrome is not the best by any means but gets the job done for cheap all motor builds.
Old Jul 2, 2010 | 05:46 PM
$amGD3's Avatar
Swaggylicious
the guy that did the dyno,also does tuning. He recommends the S300 but it's just not in my price range.
Where should i look for these chips? I see a whole bunch on the local forums like "chipped P28" etc etc, is it safe to buy used?
Old Jul 2, 2010 | 08:03 PM
fungus mungus's Avatar
I've found that tuners that recommend a certain system are more competent at that particular system. If he recommends s300, he's probably more comfortable with it and you may end up with a better tune. I know that it's expensive. I bought a P72 ECU with an s300 install used for about $500. Yes, it's expensive, but tuning is so much more flexible. The ECU is updated live, so there's no burning and re-burning of chips. Which may save you money in tuning time. Just something to consider.
fm
Old Jul 2, 2010 | 08:21 PM
h23V's Avatar
the a/f says above 15 that's not good or i hope that it was off.
Old Jul 2, 2010 | 10:05 PM
$amGD3's Avatar
Swaggylicious
Yeah I think it was getting too much flow from the tip of the exhaust because there's no cat....
Old Jul 3, 2010 | 01:03 AM
HdeucedeuceA's Avatar
Tuning is tuning, regardless of the EMS. The only differences are the extra's you get; boost per gear, launch control ect. This is assuming that the tuner knows his way around the software.
Old Jul 3, 2010 | 07:05 AM
$amGD3's Avatar
Swaggylicious
Gotcha, I'll most likely go with crome since it is the most available used on the forums and the cheapest.
Do you guys think i should make any part changes before i get it tuned? Different header? Should i invest in an IM/TB?
Old Jul 3, 2010 | 07:35 AM
d112crzy's Avatar
Get rid of the whale *****.
Old Jul 3, 2010 | 01:04 PM
projectTeG's Avatar
3in bpi. and tune. hell get a vafc on there and richen it up if you have to . your a/f are way to lean.
Old Jul 3, 2010 | 01:37 PM
project4dr-eg's Avatar
ditch the whale ***** for a true CAI, probly gain 2-5hp just from that if not more, not to mention the tq you'd get back from that sri.
Old Jul 3, 2010 | 10:26 PM
$amGD3's Avatar
Swaggylicious
Thanks everyone, I'll be on the lookout for a diff. intake,possibly different header as well...
What kind of power do you guys think I'll be able to get from tuning? +10hp? 15?
Old Jul 3, 2010 | 11:14 PM
CHiLD's Avatar
those numbers seem low imo. I have a jdm b16a with just CAI, strup 4-1 header, and apexi ws2 exhaust and i laid down 156whp untuned.
Old Jul 4, 2010 | 01:42 AM
Irrelevant, sense you can't compare different dyno charts.
Old Jul 4, 2010 | 04:31 AM
00Red_SiR's Avatar
All Motor Mentor
You obviously found a magically happy dyno. Take it to the track if you want a dose of reality.
Old Jul 4, 2010 | 06:22 AM
projectTeG's Avatar
thats abnormally high i figure its a happy dyno.
Old Jul 4, 2010 | 11:52 AM
$amGD3's Avatar
Swaggylicious
Idk,I've gone through the whole dyno thread like 3 times and there's a guy with pretty much the same exact setup and he's making 155,tuned. I was a little disappointed but hopefully with a tune I can get around 160whp
what do you guys think? Is that figure reasonable?
Old Jul 4, 2010 | 04:47 PM
00Red_SiR's Avatar
All Motor Mentor
The point is that anyone can find a "happy dyno" to give them high numbers, that doesn't mean that's the absolute final word as to how much power you're actually making. Taking it to the drag strip will quickly seperate the good feelings from the dyno numbers.
The dyno is a tuning tool, not gospel. Even if you managed to hit 160whp fully tuned in your car, I can assure you that your car won't be making that much power with the mods you currently have. Use the dyno as it's intended, TUNING, and go to the track if you want hard numbers.
Old Jul 4, 2010 | 05:22 PM
$amGD3's Avatar
Swaggylicious
The quarter mile track scares me, I snapped 2 axles in 2 weeks the last time I went. Granted that was when I still had the stock mounts which were shot to hell, I haven't gone since i've put the 75a innovative mounts in
Old Jul 4, 2010 | 05:27 PM
OH_1fstgsr's Avatar
You snapped axles with the mods you had listed? You are doing something terribly wrong. Where you just dropping your clutch?
Old Jul 4, 2010 | 05:31 PM
00Red_SiR's Avatar
All Motor Mentor
I'd say he was either running slicks and dumping the clutch at the rev limiter or he had violent wheel hop on the launches to do that.
Old Jul 4, 2010 | 07:34 PM
preloading is your friend..
$amGD3
Engine Management and Tuning
16
Jul 9, 2010 09:38 AM
Count Blah
Honda Civic (2006 - 2015)
12
Mar 25, 2010 01:15 AM
2000IntegraGSvtec
Nov 7, 2004 05:21 PM
vtec94civic
Mar 1, 2004 06:56 AM
RATEDR
Jul 21, 2001 12:19 PM
