►2000 Honda Civic Si Built LS-Vtec Turbo--POSSIBLE TRADE◄
****UP FOR A FRIEND****
2000 Civic Milano Red Si. Interior has stock Si Leather interior, good shape, little wear on driver side. Alpine CD/speakers, boost gauge boosted on 20lbs but turned down to 17. Clean title, 148,XXX on body, and 8k ish on the build and have receipts.
--HEAD--
Pr3 GSR head
GSR Camshafts
Blox dual valve springs
Supertech Titanium retainers/keepers
Blox adjustable cam gears
3 angle valve job
New stock valves and guides
Skunk 2 pro series intake manifold
Golden Eagle head gasket
Type R vtec solenoid
Type R valve cover
Blox cam seal
--BLOCK--
B18b1 LS
Decked
Hot tanked
81.5mm bore and hone
Weisco 81.5mm 9.0:1 forged pistons
Eagle H beam Rods
Micro Polished LS crank
ACL rod studs
ACL race bearings
ARP head studs
Golden eagle block guard
Golden Eagle Block girdle
NEW OEM water pump, oil pump, tensioner, cam seal, main seal
New oil pan, tapped for turbo oil drain
Golden eagle LS/VTEC conversion kit with dowel pins
Oil catch can bottom end breather kit
--Turbo--
Greddy cast iron manifold
Greddy TD05 18g turbo
Internal wastegate
Blox boost controller
GM 4 bar map sensor
Blitx Blow Off Valve
--ECU-- OBD1 P06 quick release socketed and chipped
OBD 2-1 conversion harness
--Fuel-- 255 gph walbo fuel pump
Precision 750 injectors
--Tranny--
B16 Trans
Compition Stage 3 Clutch Kit
Lightend/Machined Stock flywheel
Poly Bushings
Blox Shifter
--Wheels/Tires/Suspension-- Wheels are 16" Konig Remember 16x7 32 offset with bfg gforce tires. H&R springs on stock struts. Full camber kit all the way around! Innovative mounts. Alarm and remote start.
--Brand new fluids, new plugs, cap, rotor, fuel filter.
$9500 OBO or trade for?? Open to offers, no garbage or dumb stuff. Cash, straight trade, or trade and cash offers are cool. Just e-mail me what you have, worst case cenario is I say thanks but no thanks. Cash talks-but will not take 5K so don't offer me. Thats what the car is worth stock. Will consider 5-6K plus trade for what....?
--HEAD--
Pr3 GSR head
GSR Camshafts
3 angle valve job
Type R valve cover
Blox cam seal
--BLOCK--
B18b1 LS
Decked
Hot tanked
Eagle H beam Rods
ACL rod studs
ACL race bearings
ARP head studs
--Turbo--
Internal wastegate
GM 4 bar map sensor
--Tranny--
B16 Trans
Poly Bushings
Blox Shifter
FunctionSi
Northwest (Sales)
13
Nov 30, 2009 02:49 PM
FunctionSi
Nov 16, 2009 07:01 PM
gsrwanted
Nov 15, 2008 07:18 PM
I know you want one
nice car
