LS-V swap to ej6 help
ok i'm just a little confuse here.
pls checkd is im missing something.
plan swaping a LS-V (B18A1/B16A) w/ 00 si trans.
i have the fallowing:
-00 si shift linkage
-pct ecu
need 99-00 si T bracket (still looking)
need manual Haft shaft (still looking)
Q's:
which T-belt bracket? can i use the timing belt bracket from the B18A1 or has to be B18B1, B16?
can i use the same mounts?
what else am i missing?
suggestions, comments pls.
-pct ecu
Q's:
90Rexx
Oct 20, 2008 01:53 PM
invisible
11
Jan 30, 2007 06:45 PM
SI_niki
Apr 28, 2004 04:31 AM
