ac compressor issues
My crx started blowing warm air so I recharged it with r134 since the previous owner said it was already converted.apperently there is a leak from the compressor and it also squeeks so I want to replace it.my question is can I use a civic compressor like from an eg and just run r134 or I have to use a crx one?
I dont personally know if the compressor actually fits, but a compressor is a compressor. if it'll bolt up and fit and you get a belt that fits and the lines will match up you're good to go. Check for the wiring on compressor too. Why do you think the compresssor is bad BTW?
I believe that the previous owner just added r134 freon to a compressor that was made for r12 and he didn't empty out the system before he filled,if you put in freon you can hear escaping threw the compressor
From: I told you to wait in the truck in Texas, United States
The car either came with a Sanden or a Matshushita
and you should probably find out which one
is on it as the lines are different between the two..
There should be a tag on the compressor and
sometimes there will be one on the core support..
baybay
Aug 26, 2018 02:39 PM
2old_honda
May 29, 2011 12:35 PM
Turbo E
Aug 8, 2006 08:59 AM
