Air cond.
Old Jun 30, 2010 | 07:46 PM
1 Civic I's Avatar
Default Air cond.
If anyone knows anything about it. My blower (if thats what its called) underneath the passenger dash is making a horrible noise when the fan is turned to loud. i think if i replace this it will make the air blow harder out the vents because it seems like no air reaches to the driver side of the car.
But not only this is the prob. the ac will go cold on and off when it does blow. I was wondering if this is only needing freon or does it need something bigger?
Let me know thanks.
Old Jun 30, 2010 | 08:41 PM
Duane_in_Japan's Avatar
Default Re: Air cond.
We need to know your LO and HI pressure readings when the AC is good and cold and when its not so cold, Hondas have a history of expansion valves doing what you say is happening.
Yes, it sounds like your blower motor is shot and you may have some kind of restriction blocking air flow to the other side of the dash.
Old Jul 1, 2010 | 06:56 PM
1 Civic I's Avatar
Haha . well i have no idea how to get those readings. So i guess ill just take it to someone to look at. .
Although the blower i might be able to fix.
Pooby88
Aug 29, 2009 07:27 PM
jounion
Aug 1, 2008 11:55 AM
SedanCruiser
Aug 1, 2007 10:37 AM
DOHCVTEC190
Jul 20, 2007 07:34 AM
B18C1 '96 Coupe
10
Mar 9, 2003 12:01 PM
