How do I remove the front dust shields?
Old Sep 14, 2002 | 05:27 PM
Dr Pooface's Avatar
Default How do I remove the front dust shields?
I intended to do that today, but when I couldn't figure out how. Do I have to remove the hub, or do I just hack away at them with tin snips?
TIA
Old Sep 14, 2002 | 05:45 PM
D's Avatar
D
Default Re: How do I remove the front dust shields? (Ddub)
snips.
Old Sep 14, 2002 | 05:53 PM
markpaco's Avatar
You need to remove the hub, which requires ends up destroying the wheel bearing in the process ($60). Basically, it is not worth taking out unless you really need to. Did you get bigger brakes or something? If you really want to do it, cut them off.
Old Sep 14, 2002 | 06:06 PM
N24RE's Avatar
Default Re: How do I remove the front dust shields? (D)
snip them off....then once they are off you can remove the screws that hold them n place by twisting them out....it's a hack job....but you only end up hacking on the shield
Old Sep 14, 2002 | 06:21 PM
D's Avatar
D
actually, you can remove the screws first with some pliers. then snip just a small section of the shield out... and slide off the hub. can then be re-used if you 'really' care to.
D
Old Sep 14, 2002 | 06:37 PM
Back in Black's Avatar
Rather OG
D
Yep
Old Sep 14, 2002 | 08:18 PM
uncleben's Avatar
D
what purpose do they serve anyway? besides keeping dust off... off of what?
Old Sep 14, 2002 | 08:24 PM
Batoutahell's Avatar
Default Re: How do I remove the front dust shields? (uncleben)
Ben, we snipped Jeff's dust shields off the other week. Frankly, I didn't notice any "extra" brake dust from when I removed my shields. The only thing the dust shields do really well is reflect heat back on the brakes.
Old Sep 14, 2002 | 08:27 PM
D's Avatar
D
Default Re: How do I remove the front dust shields? (Batoutahell)
well, i suppose they keep some heat away from the Lower ball joint.. whatever. they suck.
GRM Scott's Avatar
25 Year Member
yeah, pull the rotor off, snip the shields and pitch 'em, they're worthless. couldn't hurt, might help.
Old Sep 14, 2002 | 08:28 PM
Floyd's Avatar
I removed mine when I replaced the rotors. Used a pair of vice-grips to get the screws out, then a dremmel to take a chunk out of the shield and remove them.
I suppose they keep dust off the boot, but they also keep heat from radiating to nearby components, like the plastic jacket on the abs sensor wires. Someone posted some pics of some melted parts not too long ago, but that was in race conditions.
Old Sep 14, 2002 | 09:29 PM
Here's a pic of where you make the cut. I used a dremel, or tin snips would work too.
Old Sep 15, 2002 | 09:08 AM
Dr Pooface's Avatar
Thanks for the pic
Old Sep 15, 2002 | 10:09 AM
uncleben's Avatar
can you snip it without removing the rotor?
hadn't looked at mine closely yet...
Old Sep 15, 2002 | 04:12 PM
Willard's Avatar
nope... the rotor has to come off to remove the 3 screws.
more pics.
Old Sep 15, 2002 | 09:36 PM
blykins's Avatar
Banned
Default Re: How do I remove the front dust shields? (Willard)
Call me a newbie but what is the reason for removing the dust shields?
Old Sep 15, 2002 | 09:38 PM
B2FiNiTY's Avatar
Default Re: How do I remove the front dust shields? (blykins)
Added cooling. Loose some weight. No biggie.
giff74
Mar 19, 2005 02:09 AM
