Suspension & Brakes Theory, alignment, spring rates....
Quick 92' Eg Drums to Disc question
Old Jun 30, 2010 | 01:32 PM
shotime's Avatar
Icon2 Quick 92' Eg Drums to Disc question
I have a chance to get a rear disc set-up off of a 94' civic ex is that just as good as a civic si set-up and will it bolt right up just as easy to my eg ??
Old Jul 1, 2010 | 06:11 AM
phunhaus's Avatar
Default Re: Quick 92' Eg Drums to Disc question
Yes. Yes.
Old Jul 2, 2010 | 04:19 PM
EFRue57's Avatar
94 civic ex didn't come with rear discs. they came with rear drums.
Old Jul 2, 2010 | 05:04 PM
phunhaus's Avatar
They did if you got the ABS option I believe.
Old Jul 2, 2010 | 07:08 PM
90civichb's Avatar
He is correct. The EX-S model came with ABS and rear disc brakes.
It doesn't matter what 92+ model Civic you get the rear disc brakes from (hatch, coupe, sedan), they will work. You just have to match them with the correct e-brake cables for your application. For that matter, the same applies to getting the hardware from a 99-00 Civic Si, or a 94+ Integra (earlier models as well, but I don't remember how early).
My 94 EX has all the rear trailing arms/hardware from a 92 Si. The only other part I needed was e-brake cables from a coupe with rear disc brakes (or similar - 99-00 Civic Si, 94+ Integra, etc.)
Old Jul 6, 2010 | 03:34 PM
Comenzi SUA's Avatar
I have an 93 ex EJ1 , and just did the drums to discs conversion. Can someone help me and tell what e brake cables i need? A part number will be greatest...
Thank you
redlinexd
Nov 30, 2008 05:00 AM
mcmmotorsports
Jan 3, 2007 07:43 PM
integlspwr2k
Jun 18, 2004 06:23 PM
jdmjeff
10
Nov 10, 2003 07:18 PM
bartek_b
Feb 10, 2003 02:55 PM
