what shocks to go with (non-koni gc)
I was able to pick up a set of mint GC for $50. These are OTS spring rates of 380F/250R
These are the non-koni GC. I would love to go with koni yellow but that's not a choice for me now.
What other shocks would work decently well and last a while.
I only drive my EF gsr 2-3 months out of the year, slight drag racing but more road racing.
- blisten
- kyb agx
- tokico
-.... other options?
- blisten
- kyb agx
- tokico
they will work on the koni str.t which actually is a good cheap match for those rates. $299 shipped. if you want adjustable either the kyb agx or illumina is a good shock, between those i don;t have much of a preference, both are decent pieces.
just incase someone says hey, wait, these aren't for konis, well that's true with the sport since they don't have oem style shelfs. the str.t does and is created like an oem replacement with welded on plates thus it's fine to use with what are called non koni gc's
- blisten
- kyb agx
- tokico
- blisten
- kyb agx
- tokico
and why not again? just because they're not made for the koni yellows doesn't mean that it won't work. the sleeve's will have to just sit on the collars like any other coilover sleeve.
The Koni Sport doesn't have a fixed spring perch like a typical shock, and anything sitting on the circlip needs to both hold the circlip in place and spread the load correctly on it. Running a GC sleeve on top of the spring perch won't do this.
really never heard that before...... hmm.... i have some skunk2 coilover sleeves on with the O rings on. the collars don't move, hopefully not at all.
I checked bilistien and they only have HD(heavy duty) & TC (OEM replacment) for the EF... they don't offer the sport version...
the agx and illumina are both solid choices. see what you can get for prices and get the cheaper of the two. if you need an adjustable shock, either will work. for a non adjustable the koni str.t is very hard to beat.
i had illuminas and i now run the EIbach Pro-Damper. Both are awesome dampers. Im 99% sure the Eibach is the same as the Koni STR.T. Both made in argentina, both look identical and both have the normal welded spring perch.
Feb 28, 2012 12:43 PM
