Real Street Overstock Sale MUST LOOK Heavily Discounted Internals, Turbos, Clutches,
We have a couple things that we are looking to get out of here. Just these specific part #s will have discounted rates. Take advantage now! Call 407-695-7223 or PM us.
www.realstreetperformance.com
SRP Piston 149199 D16Z6 Standard Bore 9.0 Compression $429.99
SRP Piston 149217 B-Series Near Flat -3.9cc so about 9:5:1 on LS/GSR and 9:1 on B16 engine. 81mm bore size $429.99
JE Pistons 185922 B Series 3.5cc Dome 85mm so about 12:1 on LS/VTEC setups will take $499.99
JE PIstons 242878 82mm -8.9cc Dish around 9:1 depending on the setup. $499.99
CP Pistons SC7122 85mm 12:5:1 4.7cc Dome $499.99
CP Pistons SC7110 81mm 9:1 Compression $499.99
CP Pistons SC71422X K20A 87mm 12:5:1 Lighweight X Piston $539.99
CP Pistons SC7132 H22 87.5mm 11:5:1 $499.99
Garrett GT2871R Turbo $1050
Garrett GT3582R $1250
Garrett GT2860RS Disco Potato $1000
Wiseco K541M81 81mm 9.0 compression for GSR or LS $475
Wiseco K594M84 8.25cc 84mm so 13.2+ compression $475
Brian Crower H22 Stainless Steel Valves BC3030/BC3031 $270
Brian Crower BC0013 Stage 3 B16/B18C Cams $420
Brian Crowre BC0011 Stage 2 Turbo B16/B18C Cam $420
Cometic C4198-030 88mm H22A Headgasket Pre 97 $80
Eagle CRS5290H3D where out of the packaging so it has surface rust on them that can be cleaned up and the box is greasy but the rods are "new" as in never been run or installed in a motor $255
Eagle CRS5394A3D where out of the packaging so it has surface rust on them that can be cleaned up and the box is greasy but the rods are "new" as in never been run or installed in a motor $255
Probe B Series Flat Top 81mm Pistons with Rings $385
Probe B Series 81mm Dome + 7.1dome with rings so around 12:1+ $385
Probe B Series 81mm with rings with rings -7.7cc low compression $385
Probe Ultra Light I beam LS Rods $275
Probe H Beam LS Rods $275
ACT H025 B Series Hydraulic heavy Duty Pressure Plate $215
ACT 3000105 B Series Hydraulic Street Disk $125
Competition Clutch Stage 4 B Series Hydro Kit 6 Puck Sprung only pressure plate and disk $300
Supertech HEVN-1003 and HIVN 1003 D16A6 Black Nitraded SS Valves $230
Competition Clutch 8037-2100 Stage 2 Full Kit for RSX $320
Honda OEM D16Z6 Headgasket $60
ARP 208-5401 ARP H22 Main Studs $95
AEM 30-2821 4 Channel Twin Fire Ignition with AEM 30-2850-4 pack Short Pencil Coil set MAKE OFFER TOO LOW***
Innovate LM2 Missing sensor, missing the outside white innovate box but has the carrying case. $250
Precision Injectors 042-0950 honda 1000cc $275
Precision Injectors 042-0880 Honda 880cc $250
Precision Inectors 042-0440 honda 440cc Injectors $210
Skunk2 Pro Series B16/B18C5 Type R Intake Manifold $270
Precision Turbo GT3076R $1225
Garret GTX4294R Turbos available with 1.12 or 1.28 housings $2650 I have 3 of them at this price
Garret 57 Trim T3/T4 $700
thanks again jc and the rest of the guys at real street performance. deffinately suggest doing business with you for all you people out there.
Pippen_001
16
Jul 28, 2006 07:48 PM
