Head Trouble
Old Jun 29, 2010 | 07:46 PM
chadleehonda's Avatar
Icon2 Head Trouble
I have a 95 Civic with b16a2 swap..I was wondering how much of a power increase i'd make if i put gsr head with brian crower stage 3 cams, brian crower valves & valve springs & retainers with polish and port job? Also would i have more top end if i put gsr trans on b16 engine?
Old Jun 29, 2010 | 07:55 PM
thumper64's Avatar
Default Re: Head Trouble
15-20hp?
And for NA, keep the B16 trans. It has a lower final drive and shorter gears to take advantage of VTEC better since it's less torquey than the b18.
Old Jun 29, 2010 | 08:14 PM
would i be better off just doing all those upgrades to a b16 head??
Old Jun 29, 2010 | 08:18 PM
-__-'s Avatar
if you get it TUNED after all that work you might be able to make more. If you do that same work to the B16 head, it will be thesame. no need to change the head. Also consider slapping the head on a GSR block or something. Give u lots more torque.
Old Jun 29, 2010 | 08:37 PM
all i know is i wanna make as much power as possible without rebuilding the bottom end right now
Old Jun 29, 2010 | 10:40 PM
LuczOr's Avatar
Originally Posted by thumper64
15-20hp?
I agree with this, perhaps more though, since the gsr head has slightly better compression than the b16.
Old Jun 30, 2010 | 08:30 AM
so please help! which should i do modificTIONS TOO..B18? OR B16 HEAD?
Old Jun 30, 2010 | 12:00 PM
apexi_rsx's Avatar
b16 head flows better stock for stock to the gsr head. i would say keep the b16 head and work form there save your money.
Old Jun 30, 2010 | 11:19 PM
thumper64's Avatar
apexi rsx, that is an outdated and false argument that people really need to quit perpetuating. If you put both heads on a flow bench, the difference is so minimal that it will not be noticeable. Better cams, aftermarket intakes, adding ITR style valves, a mild port job, a velocity stack, etc will make more of a difference.
Old Jul 1, 2010 | 07:19 AM
apexi_rsx's Avatar
why not just save the money and do all that work to a b16 head instead of buying another gsr head for no reason....
Gsrsi
Dec 3, 2011 04:05 PM
patrickracing
14
Aug 19, 2010 01:11 PM
HondaAP1
Apr 19, 2009 12:17 PM
Spectrum24x
Feb 10, 2005 06:50 PM
MrSmith
Mar 23, 2002 01:30 PM
