TODA C2 Camshafts cant find any good info on them
Old Jun 29, 2010 | 05:58 PM
slick1851's Avatar
Default TODA C2 Camshafts cant find any good info on them
A set has come up forsale and im interesed in them
I know super street is lame, but in there B vs K shoot out the B series powered coupe is what they choose running toda C" cams and a 2000c motor. Power numbers were some were
So im wondering what C2s" are capable
Old Jun 29, 2010 | 06:00 PM
slick1851's Avatar
Default Re: TODA C2 Camshafts cant find any good info on them
FYI ive got a 84.5x89 dart block that im building....
Its a long block built for boost, but I dont have the time for a nasty turbo setup that the motor is capable of.
Im looking to make 240whp NA, this isnt my daily driver but its a street car
Old Jun 29, 2010 | 07:42 PM
092eg6's Avatar
c2 cams should b able to reach that level of hp on a 2.0 b set-up, as long as u have all the supporting mods to go along with it.
Old Jun 30, 2010 | 06:11 AM
slick1851's Avatar
Yeah but there is no info really on them
Old Jun 30, 2010 | 08:29 AM
092eg6's Avatar
what kind of info u looking to get?
Old Jun 30, 2010 | 09:25 AM
slick1851's Avatar
Anything
Old Jun 30, 2010 | 09:41 AM
TheShodan's Avatar
Moderator
You just need to try harder.
Here: (This is your only spoon feed only because I LOVE TODA RACING, and have only run Toda and Jun Cams for over 13 years)
http://www.todaracingusa.com/catalog...idCategory=143
Toda Spec C2
Intake Lift 12.5mm
Int. duration 260@ 1mm -- 295@ 0mm
Exhaust lift 12.5mm
Exh. Duration 260@ 1mm --- 295@ 0mm
This cam mixes the midrange power of the Toda B cam with the top end of similar to that of the JUN Type 3 and Skunk2 Stage 2. Power gains from 4500rpms all the way to 9000rpms. This is truly, the best overall cam for both midrange and top-end power. They might not give the top-end gains of the Skunk2 Stage 3 but you get more midrange and these cams can be used on the street with the right set-up . Due to the crazy off-VTEC lobes the idle is ever so slightly rougher than stock, just like the Toda B cam. I recommend using Toda cam gears with these cams along with a Toda, Power Enterprises, or Gates timing belt.
You need over 11.5:1 compression and uprated complete valvetrain beyond Type R to run these. valve lash and seat pressures are at oem specifications.
Your one spoon feed.. hope it was tasty ;-)
Old Jul 1, 2010 | 11:16 AM
slick1851's Avatar
Nice that was the info I was looking for!!!!
Old Jul 1, 2010 | 02:46 PM
OH_1fstgsr's Avatar
Which are Toda C2's similar to Skunk Pro2+'s or Pro1+'s?
Old Jul 1, 2010 | 04:22 PM
092eg6's Avatar
Pro1
Old Jul 1, 2010 | 04:42 PM
Mashimaro's Avatar
Toda B's recommended valve lash is 0.2mm cold btw!
Definately invest in a stronger t-belt. my Toda B's and Toda springs have destroyed my Toda belt after 2 years of use...
Old Jul 1, 2010 | 04:48 PM
TheShodan's Avatar
Moderator
Don't know how that happened to you. People tend to overtighten high tension belts thinking they are like OEM and will stretch over time when they won't. On my older TODA car (now sold to my brother) has had 4 years on the belt without a hitch
As for the valve lash: OEM is:
0.15-0.19mm (0.006-0.007 in.) on the intake side
0.17-0.21mm (0.007-0.008 in.) on the exhaust side
So I wasn't far off when you're saying 0.2mm cold
Old Jul 1, 2010 | 04:52 PM
Mashimaro's Avatar
So I wasn't far off when you're saying 0.2mm col.d
for some odd reason my belt was getting a bit loose...i put a new Toda belt and tensioner and tensioner bolt in just before a track day last week and it loosened a bit =S
when it was loose and 'oem spec' for tightness, my motor sounded like WW3 going on. tightened it a bit, it's super quiet now...odd eh?
anyways, i don't mean to thread jack. i think i'll post up another thread on this soon with pics of my shredded tbelt
Old Jul 1, 2010 | 05:47 PM
Black R's Avatar
25 Year Member
Ya I just change my timing belt more often than most people - mainly for peace of mind.
And I run it tight as ****.
I have used a PE belt, and am currently using a toda timing belt.
This is with spec C's and toda valvetrain.
Old Jul 1, 2010 | 08:35 PM
koczeka's Avatar
Originally Posted by 092eg6
Pro1
Old Jul 2, 2010 | 08:32 AM
slick1851's Avatar
It's these or Pro2s setup with the right compression and header. To get the most out of it, to many people build these cars the wrong way.
Old Jul 3, 2010 | 11:03 AM
TheShodan's Avatar
Moderator
Pro2's are a bit much. you might as well keep the TODA C2 or the Pro1s
Old Jul 3, 2010 | 12:47 PM
slick1851's Avatar
How would pro2s be to much? I'm running a 2.0 84.5x89 build
Ive got 1mm over sized valves and a street port, motor is going to be clayed and im ordering pistons with valve reliefs for extra clearance.
Cams will determine what my compression is going to be
My dynamic compression not my static
Old Jul 3, 2010 | 04:28 PM
TheShodan's Avatar
Moderator
Many people have said it was never "too much" on a 2.0 litre, only to find that it was not as "streetable" as you believe. Check the ads on the marketplace. There are a lot of them for sale from people that believed that their build "on paper" was ready for the Pro2s only to find that they didn't like the powerband, idle rpm, and characteristics that were given by the pro2s for ones that were more usable on the street, LIKE the TODA C2s.
Don't just look at the build sheet. Look at the feedback from those who have sold their cams for something else.
Old Jun 26, 2012 | 11:04 PM
civictoda's Avatar
i'm using toda c2 and the tuner can't seem to tune my car to reach 18.00 kg-nm of torque. previous cams s2 stage 2 i can get torque 18kg-nm. i decided change to toda cam is beause i want the power soon as possible.s2 s2 peak torque is at 6k rpm.while toda c2 peak torque at 4k rpm. but my tuner only manage to get 17.88 torque only....he says my car CR is low. he said try get toda c.
is this true? toda c can compensate my low CR of car??????
Toda Spec C2
Intake Lift 12.5mm
Exhaust lift 12.5mm
Old Jun 27, 2012 | 06:54 AM
TheShodan's Avatar
Moderator
No. Camshafts won't change your static compression, but may alter your effective compression. What are you trying to do with this car besides "power as soon as possible"? Cams have characteristics like many other parts other than making power. Please be specific as to what you're trying to handle here.
lindseyhunt1090
Apr 23, 2016 11:06 PM
N1 Andy
30
Jan 16, 2009 11:03 AM
Amused
Jan 21, 2006 10:32 AM
blazin
Feb 12, 2004 10:41 PM
TEGPOWER44
Jul 9, 2002 11:08 AM
