ITR cam
Old Sep 14, 2002 | 04:00 PM
AznInvasion's Avatar
Default ITR cam
i was going to buy a ITR intake cam, but still use my gsr exhaust cam. does any1 know if that is ok for my motor? i think i read somewhere that ITR exhaust cam is the same as the GSR.
Old Sep 14, 2002 | 04:06 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: ITR cam (AznInvasion)
I ran the CTR cam with the GSR exh cam for several months and without a fuel controller and it was fine. After you install the cam just be sure to check that your timing is within spec. Mine wasn't and my CEL came on. After I set it back to 16 degrees (and then later to 18 degrees) the CEL never came back on.
As for the GSR exh cam being the same as the ITR exh cam, I do not believe that is true.
[Modified by Gee3, 11:08 AM 9/15/2002]
Old Sep 14, 2002 | 04:08 PM
Malice's Avatar
New User
Default Re: ITR cam (Gee3)
As for the GSR exh cam being the same, I do not believe that is true.
yea, gsr and itr exhaust cams are different
Old Sep 14, 2002 | 04:30 PM
Default Re: ITR cam (MaliceGSR)
well what would be better to get booth the cams or will juss the intake be fine? my setup will be the follwowing:
skunk 2 IM
skunk 2 cam gears
chipped p28
dc header
aem intake
Old Sep 14, 2002 | 04:43 PM
Malice's Avatar
New User
it'll be better to have both. easier to dial in. there is an issue of overlap with just one
Old Sep 14, 2002 | 06:20 PM
Gee3's Avatar
I did one at a time because I could only afford one at a time. hehe!
Old Sep 14, 2002 | 09:41 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
ITR and CTR exhaust cams are the same. i believe u mixed them up
bigjon1378
Mar 22, 2015 03:48 AM
civicdragger818
10
Jun 16, 2004 08:26 AM
skunked
Dec 12, 2002 10:01 AM
1fastGSR
Sep 7, 2001 08:12 AM
MRDC2
Jul 4, 2001 03:02 PM
