FS: JDM 99 B16a SIRII Complete Motor
I got a JDM 1999 b16a SIRII motor. Comes with everything you need to do the swap. Motor has about 50K miles on it.
- b16a Motor
- GSR Tranny
- ECU (P2T)
- Axles
- Motor Mounts
- Alternator
- New Starter
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
The only thing you will need is a new clutch and a shift linkage as well as I can't seem to find it in my garage, however, I have taken these things into account and have priced the motor accordingly. The motor does burn a small amount of oil, about 1/4 of a quart every two weeks, so nothing bad, and it only burns oil if you go past 5-6K RPM. Under normal driving conditions, it doesn't burn oil. Located in 92704 (Santa Ana/Irvine area). If you have a truck, you should be able to carry everything home, no problem.
NEW PRICE: $1100 FIRM, no lower.
- b16a Motor
- GSR Tranny
- ECU (P2T)
- Axles
- Motor Mounts
- Alternator
- New Starter
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
WHOOPS! GSR Transmission, and no, there are no grinds at all in any gears...but like I said above, you will need a new clutch, the last one was slipping.
