what size gauge for pos. battery wire...
Old Jun 29, 2010 | 09:44 AM
mikej94civex's Avatar
Default what size gauge for pos. battery wire...
i'm relocating my battery and need to kno what a safe size wire is to be used...and can it be regular stereo wire for like amps?
Old Jun 29, 2010 | 09:51 AM
4g4dcruisin's Avatar
Default Re: what size gauge for pos. battery wire...
4g or 2g copper wiring.
Old Jun 29, 2010 | 09:02 PM
thanks, btw i'm runnin an odyssey l/w battery soon does that m,atter or will 2 gauge be fine?
Old Jun 29, 2010 | 09:22 PM
87 SiviK Si's Avatar
OK... stock cables are 6 gauge. but since you are relocating your gonna need a bigger cable (lower gauge) because the change in resistance due to length of the cable.
If you are keeping the same factory location upgrade to 4 gauge.
If you are relocating use 2 or 0 gauge, whatever you have the money for, 0 gauge would be the best but really thick diameter and stiff braid. This would all depend on how/where you are running the cables.
BEST tip for getting cable is go to a welding supply store. they have the best wire and its made for the high AMPs and you can get it custom cut to whatever length you need. they will be able to attach the cable ends on too.
Old Jun 29, 2010 | 09:38 PM
aquito's Avatar
im about to do mine and i bought the same wire i use for my amps, knukonceptz 0 gauge..u can get it at knukonceptz.com believe me man their wire is great
Old Jun 30, 2010 | 06:40 AM
Good luck with the relocating, i'll be doing that myself!
Old Jun 30, 2010 | 07:20 PM
thanks everyone, i'm relocating it to the trunk, and i will go with 0 gauge to be safe, oh another thing would i need to put a fuse somewhere in thast wire?
Old Nov 19, 2021 | 01:03 AM
ShadoeFax 86's Avatar
Depend on what you plan on running off the positive terminal of the main battery. The battery is really just to start the car since it needs a massive punch of energy to turn an engine but alternator keeps car on & electricity flowing & charges battery. If you plan on hooking up an amp or subs then yeah you need fuse, if you want to add anything that's not stock & run it off battery than yeah you should add fuse to be safe. Inline fuse within 6-12in of positive terminal. If you're just relocating the battery & running the stock equipment you shouldn't need any fuse.
EM1 Resto
12
Oct 14, 2009 12:42 AM
shaggyeg6si
Jun 18, 2008 06:46 AM
essex
Jun 7, 2008 11:11 AM
imadigitalgod
Audio / Security / Video
Jun 4, 2008 01:47 PM
4DRmafia
23
Oct 10, 2005 07:36 PM
