90 Accord EX Cruise Control
Old Jun 29, 2010 | 09:43 AM
memphisrains's Avatar
Icon2 90 Accord EX Cruise Control
90 Accord EX automatic with 415K: My brake lights were staying on and I replaced the plunger/solenoid that operates when the brake pedal is depressed. I also replaced the rubber plug on the brake lever that the plunger on the solenoid touches.
The cruise control was operating prior to this replacement, now it isn't. I checked the connection to the solenoid....OK. I also checked the fuse....OK. When I depress the set or resume buttons on the steering wheel...no response and no light in the dash. Anyone got an idea on what next?
Old Jun 29, 2010 | 12:39 PM
sgraham01's Avatar
Default Re: 90 Accord EX Cruise Control
you may have gotten a bad brake switch.
Old Jun 29, 2010 | 04:48 PM
poorman212's Avatar
Also double check the "adjustment" between the new switch and the new "stop". If it is "out" by a little bit that could cause the issue as well.
Old Jun 30, 2010 | 03:08 AM
Thanks for the response. I'll tighten up the clearance. I have the brake lights working but I will run the switch a little closer to see if that helps.
Purple_pigeons
Oct 18, 2018 01:18 PM
HondaDadx2
Dec 5, 2015 12:54 PM
PREACHERBREW
May 20, 2008 02:09 PM
H2290
Jul 31, 2007 12:15 PM
