Threw a rod.. Can i still run the car safely on 3 Pistons?
Old Jun 29, 2010 | 08:24 AM
EatMyVTEC :]'s Avatar
Default Threw a rod.. Can i still run the car safely on 3 Pistons?
As the title says. If so how? Thanks for your help.. I did use the search button nothing came up so don't flame me please.
Old Jun 29, 2010 | 08:26 AM
Linked's Avatar
Default Re: Threw a rod.. Can i still run the car safely on 3 Pistons?
dont you have a hole in your block?
Old Jun 29, 2010 | 08:27 AM
No I don't.
Old Jun 29, 2010 | 08:29 AM
I remember reading on another forum to just cut the fuel to the cylinder. But how would I go on doing that.?
Old Jun 29, 2010 | 08:34 AM
azandford's Avatar
how did you throw a rod and it not go through the blocK?? im guessing you really didnt throw a rod how do you know or are you just guessing?
Old Jun 29, 2010 | 08:38 AM
Dkober101's Avatar
Originally Posted by EatMyVTEC :]
Life starts at 5500 RPM .
My call is a spun rod bearing.
Old Jun 29, 2010 | 08:51 AM
titi_vtec's Avatar
if i was you i leave like that, and try to fix it because late it going to brake other stuff, for example u are runing on tree pistes there is a imbalance on one part of the engine and this will make problems, good luck with that
Old Jun 29, 2010 | 08:53 AM
Linked's Avatar
most likely
@OP you DID NOT throw a rod if you didnt put a hole through your block or oil pan (and in rare cases the head :S)
how the hell did you conclude you threw a rod if you didnt rip opent he motor or didnt see an exit for the rod
Old Jun 29, 2010 | 08:55 AM
Duane_in_Japan's Avatar
Disconnect the fuel injector connector from the bad cylinder, isnt it a little embarrassing to drive around with all that noise coming out from under the hood.
Old Jun 29, 2010 | 09:03 AM
I havent driven it. I turned it on the other day and while i was driving the engine started to knock I thought i had thrown a rod. I mean I'm no expert I was just guessing. What do you think it can be?
Thanks for the help in advance
Old Jun 29, 2010 | 09:23 AM
KevinBrown's Avatar
Sounds like spun bearing. Run it til it blows or find a cheap replacement.
Old Jun 29, 2010 | 09:27 AM
Dkahn18's Avatar
if its not knocking too bad you may be able to fix with minimal dmg. the last thing i would do is "run it until it blows"
And no, cutting the fuel to the cylinder wont change ****. Its still hooked to the crank, which still rotates.
Old Jun 29, 2010 | 10:01 AM
EJ6-2nr's Avatar
swap it for a D
Old Jun 29, 2010 | 10:10 AM
98CX's Avatar
Ouch that sucks, but as all these guys have said, if you try and run it sooner or later something will go and with it the whole engine. Also, I notice your location is 3OH!3, +1 for Colorado..lol
Old Jun 29, 2010 | 01:21 PM
Ok I found out what the problem was. A tranny mount was loose lol. Made a clanking noise and it seemed like it was in the engine.. Phew. Also I tried to take it out for a drive but it died on me. I tried to turn it on once again but it would just turn over not turn on. I checked the battery and everything.. Tried jumping it but to no avail. Any suggestions? And thanks, Where you from 98cx?
Cap rotor and wires seem fine? Really confused on this one
Old Jun 29, 2010 | 01:22 PM
Mile High everyday lol. Might be less air but our Honda still run like champs ^_^
Old Jun 29, 2010 | 01:31 PM
98CX's Avatar
Lol, I was actually thinking of suggesting it may be a lose motor mount, close bun not quite...anyway I am from around the Arvada area.
Old Jun 29, 2010 | 01:38 PM
Linked's Avatar
OP check for fuel/ spark, then check timing report back your findings
incase you didnt know how to check for fuel/ spark
spray flammable liquid into your throttle body and try to crank it, if the engine starts it has no fuel
take a spark plug wire out of the and stick a fresh (not rusty) screwdriver into the spark plug area, put the metal area of the screwdriver VERY close to a piece of the body but not touching it, then crank it
if you see electricity jump from the screw driver to the body then you have spark, if you dont see the electricity then you dont have spark
Old Jun 29, 2010 | 01:39 PM
Nice I'm from Up north. You go to the meets.?
Old Jun 29, 2010 | 01:40 PM
Thanks alot linked very helpful I will try that
Old Jun 29, 2010 | 03:24 PM
thumper64's Avatar
I know the problem is resolved, but if it's a D series, what's wrong with running it until it blows? They are cheap and have the lowest power output of any motor that you can run in a civic. They're not even worth rebuilding.
Old Jun 29, 2010 | 04:48 PM
Riviera's Avatar
Kseries frankenstien fTwwwwwww! i havnt got one but i want one...
200atwkw N/A mmm
Old Jun 29, 2010 | 05:18 PM
carfreak2020's Avatar
check your ground that goes from the tranny to the body my b18 was doing the same thing it would just turn over without starting.....hope it helps
Old Jun 29, 2010 | 07:13 PM
Thanks for all your replies, Linked I checked everything and it seemed to be fine. I was thinking about running until it blows to be honest and just buy a d16 for cheap. And I will check in the morning carfreak thanks for your help really appreciate it =]
Old Jun 29, 2010 | 07:21 PM
builthatch's Avatar
MiG-21 superfan
a d16, even non-vtec, with p29 pistons will make more power than a stock b16 or stock b18b. in fact an bone stock sohc vtec makes the same tq but with a wider band. they are fantastic commuter engines - super easy to work on, parts are readily available because of people like you, etc.
not everyone wants to spend thousands of dollars to make their 16 second commuter car a 14 second commuter car.
