Where/What to buy.. ZC injectors?
Old Sep 14, 2002 | 03:38 PM
1990hondaHF's Avatar
Default Where/What to buy.. ZC injectors?
I need to get some new injectors and these are the ones I've found so far:
http://javascript[img]http://images....6210464');
http://www.nopionline.com/index.cfm?...ection%20Valve
http://www.jcwhitney.com/SearchCatCo...equestid=59728
some of those flow same as stock others flow 10%....I'm sure some of you out there have bought new ones....so where did you get them? Did you go with stock flow or go with a higher flow? Would 10% more be too much? Thanks.
I have a ZC DOHC with a H/I/E ...if that helps.
[Modified by 1990hondaHF, 7:42 PM 9/14/2002]
Old Sep 14, 2002 | 05:22 PM
DLB1994's Avatar
Default Re: Where/What to buy.. ZC injectors? (1990hondaHF)
why do u need new injectors
Old Sep 14, 2002 | 06:16 PM
ScottEK's Avatar
Default Re: Where/What to buy.. ZC injectors? (DLB1994)
Why would ZC injectors be any different if the fuel rail is swappable from the Si? (I asked if it was swappable before and the conclusion came to yes, is it not possibly?)
Old Sep 14, 2002 | 08:58 PM
1. The HF ones have over 130k miles and cause my car to hesitate
2. The ones that came with the engine are OBD-1 injectors...and so is the engine.
I heard I could remove the resistor box but I'm not sure about that...and yes I have tried a full tank of gas with a fuel injector cleaner additive.
[Modified by 1990hondaHF, 1:03 AM 9/15/2002]
[Modified by 1990hondaHF, 1:07 AM 9/15/2002]
prelude182
Mar 17, 2010 01:19 AM
jining
Oct 8, 2009 01:53 PM
miketurbohonda
Nov 27, 2004 06:12 AM
Morbspeed
Jan 13, 2004 05:51 PM
crxtreme27
Jul 30, 2002 09:21 PM
