last time
Old Jun 28, 2010 | 10:22 PM
corps's Avatar
Default last time
i got coilovers brand new check them out ASKING $500 OBO!!
yes they are named brand! not no named i no wat it is u can look it up later if u decide to buy it, its one of the first model ever made so u will be the first to test them out.their site is already up but not even completed n they make oem suspensions
this is the exact specs for it and its an up coming brand its NOT no brand name shiet!
Description:
SPORT is a kind of shock absorbers with high-performance and adjustable damping force, which designed specially for
Street Sport, making driver have a better control and feel easier, comfortable to drive under any road circumstances.
Features:
* Use big size and high-precision piston, which can produce a hard damping force when driving in poor road or turn in high speed, ensures a safe driving.
* Using big size cylinder to reduce oil temperature effectively when in long-distance driving, and improve stability of damping force.
* With high-pressure nitrogen gas, can reduce oil temperature effectively, inhibit bubble formation, and make damping force to be more stable.
* By using patent rubber upper mount, noise can be lowered effectively, and give driver a comfortable feeling during driving.
* Adjust damping force by using a **** with 16 clicks, which can meet driver's various requirements.
* By using single spring, shorten damper travel and let it matches track conditions.
* With adjustable bottom bracket,car height can be lowered in the range of 0-60mm.
ek rear seats - $40
headliner - $45 7/10
cargo cover - $75
stock suspension - $40 all unknown milleage
a pillars panel - $20 all
c pillars panel - $20 all
rear seat belts all - $25
rear trunk panels everything except for very top piece - $35
oem acura radio - $20
window motor n wiper - $25
n crx
take the whole shell n all crx parts for 100 bucks!!
from crx :
crx left n right door step sills - $20 both
crx left n right side skirt - $25 both
crx blower box - $15
crx sway bar - $20
crx left n right oem camber kits - $20 both
crx left n right front disk brakes with calipers! or u can get seperate! - $30 all
crx left n right lower control arms - $20 both
crx brake master cylinder - $20
also have the steering wheel column that goes thru the firewall and have ignition with keys! - $40
also got 2 13" donuts bald and 2 14" donuts bald also - $20 each
and also got 99 - 00 civic front bumper the cheap ones - $15
lmk at 6265896165 or email @ xmrxnguy3nx@yahoo.com
Old Jun 28, 2010 | 10:24 PM
EfGirl's Avatar
Default Re: last time
holy macaroni i seen that crx all over HT...lol
Old Jun 28, 2010 | 10:25 PM
corps's Avatar
bump
Old Jun 29, 2010 | 09:56 AM
corps's Avatar
bump
Old Jun 29, 2010 | 10:04 AM
KINGVEM^^ED6's Avatar
STOP MAKING THE SAME FUDGEING THREADS ALREADY
Old Jun 29, 2010 | 10:19 AM
corps's Avatar
other one got banned this is only one haha
Old Jun 29, 2010 | 10:28 AM
Turbo93Eg's Avatar
i would so buy them if i had an import..bump ttt
Old Jun 29, 2010 | 10:29 AM
It got locked because your posting the same **** over and over
Old Jun 29, 2010 | 10:30 AM
r.wright's Avatar
stop posting the same things multiple times
xmrxnguy3nx
Jun 25, 2010 11:25 AM
b18C1_liLkyLe
Honda Motorcycles
May 12, 2008 05:02 PM
EddiEEchung
Dec 3, 2007 10:10 PM
z0om
Honda Motorcycles
Apr 9, 2007 10:24 AM
