Removing Door Panel 96 Accord
Old Jun 28, 2010 | 05:36 PM
Honda CA's Avatar
Icon2 Removing Door Panel 96 Accord
I'm trying to get the driver's door panel off a 96 Accord sedan, to fix a power window problem.
Anyone have a tutorial or schematic or advice on where all the screws and clips are? And what order to do things?
Thanks.
Old Jun 28, 2010 | 06:12 PM
silent1jt's Avatar
Default Re: Removing Door Panel 96 Accord
removing the door panel is fairly easy. just take of the screw on the door handle and arm rest. Then use a flat head screwdriver to pop the clips, start from the bottom. Once all the clips are off just lift it upwards and you are set. Before you completely pull the door panel out make sure to remove the door hinge from the door handle carefully. Reverse steps to put back on. GL
Old Jun 28, 2010 | 07:10 PM
Balwin's Avatar
make sure you take off the black triangle and that plastic push in screw as well.
and when you get it off, you can unplug the door light pigtail too. It took me the longest time to figure that out. the tab is upside down and you cannot see it.
Old Jun 28, 2010 | 07:26 PM
silent1jt's Avatar
that too...i had forgotten about those things, thanks balwin
Old Jun 29, 2010 | 09:38 AM
Honda CA's Avatar
Thank you both for your help!
I'll let you know how it goes.
curvenut
Nov 4, 2013 05:21 PM
honest.hank
Aug 17, 2005 07:55 AM
ryan ortego
Jul 31, 2005 09:17 PM
manishhb
May 19, 2005 06:56 PM
