mini turnbuckle?
Old Jun 28, 2010 | 03:10 PM
slowhitEJ1's Avatar
Default mini turnbuckle?
what i need is something that will function as a turnbuckle in the push orientation, as i need to hold something down from the top, and there is nowhere to mount anything underneath and pull.
I also need an eye on both ends, one for a bolt to go through, and the other for a pin to go through with a c clip on the end. does anyone know where i can get a tiny turnbuckle, or have any other ideas for something that will work?
i've tried drilling a bracket, but without fancy equipment i can't seem to get the measurement perfect enough to hold it down and still fit. any help is greatly appreciated.
Old Jun 28, 2010 | 03:28 PM
javierb14's Avatar
Default Re: mini turnbuckle?
you should be able to find something like that on mcmaster.com or midwestcontrol.com
Old Jun 28, 2010 | 05:14 PM
TurboChurch's Avatar
how about a threaded Heim joint at both ends of a rod. Sounds about like what you described. like one of the radius rods on a traction bar setup only smaller in size.
Old Jun 29, 2010 | 08:07 PM
slowhitEJ1's Avatar
thanks guys. I wasn't able to find anything small enough for what i need, so i might just weld it shut. this was the last option i had, as i wanted to be able to sell it later if i had to, unwelded, but i might just keep it. who knows.. thanks for your help guys!
sc34dc4
Welding / Fabrication
Jun 3, 2011 01:27 PM
91GEDHATCH
Jun 19, 2010 07:56 PM
poweroftheblah
Apr 28, 2010 01:06 PM
ambertch
Sep 8, 2009 02:11 PM
COMplex.
Jun 3, 2003 08:38 PM
