CROWER cam broken 3 spots, 4 pieces.
Peep the link
http://midnightperformance.com/images/crower
[Modified by CRXB16aJDM, 3:31 PM 9/14/2002]
What the HELL happened here? That does not look good and this isnt the first picture I've seen of broken Crower cams. I cant believe that they cant get it right!!! Any idea on how this happened??
it happens because crower does not use any kind of copper coating on their cams and they dont make them to flex so they snap.
As far as I'm concerned, only one thing can cause this to happen...improper heat treating. When you heat treat a cam it is important to only heat treat the lobes and NOT the whole shaft. The copper color you see between the lobes actually is what stops the heat treating process on the shaft. If the shaft is too hard, it WILL snap like this. Sometimes a reground shaft on a Honda core is actually stronger than a new billet. Everyone here thinks regrounds are not the way to go but they are wrong.
For a while, I've been looking into getting Crower cams for my GSR, but after seeing broken Crower cams posts every other week, makes me think twice about those cams.
let me guess, you used someone other than Crower for the springs/retainers. Most likely JUN.
High lift cam, retainer meets valve guide, cam breaks. Seen it before.
Didn't know the S2000 head fit on a B16, I guess it don't.
[Modified by Mista Bone, 6:46 AM 9/17/2002]
looks like what happened to my brothers car, he was racing jack on the way to the dyno and the cam broke. the valve springs were not stiff enough and the motor was pretty much screwed
I've seen it 6-7 times, but nobody will comment on what springs/retainers they were running, or if they even bother to check for spring bind, or the retainer bottoming out in the valve guide.
Most aftermarket springs use a thinner diameter wire for the springs to allow for more lift AND a recessed retainer that will have a higher spring installed height.
The original poster lists ITR inners and Crower retainers on the info page.
I have Crower 63403's and I have had no prroblems. I'm using Crower springs, and Crower retainers.
One case was using Toda valvetrain, another was using stock valvetrain.
Check TODAs site they talk about use of there cams with diff springs, but I have seen where use of stock springs are used but some are swapped using a diff part number.
Springs would be a good place ot start. Blaming Crower for the cam being broken, I dont hold fault there. I have seen a cam dropped and watch it break, that will happen, to be strong and have good wear resisntance it becomes brittle.
Another Obvious spot to check is Valve Lash, and even checking the Cam Jounals, if they were not checked when the head was setup that could happen to snap a cam as well.
Who did the work on the heads, I would be asking them questions like. Did you do any machine work to the heads, if so did you check all the measurements. Did you check the oil gap on the cam. EVER HEAR OF PLASIGAUGE
Did he warentee his work. Got the Right Valves installed in the right head. Are they the correct size valves for that block, if valve stem is wrong length that could be fun on the cam as well.
Check your Rods, Are they Stroker rods with reg pistons.
Any Number of things could be the reason but check those out first.
This Aint Yo Momma's Honda
Merlin, my points exactly.
Most people have NO CLUE about building a motor. The first book I suggest is "How to Hot Rod the Small Block Chevy" as it covers all the basics needed.
I picked up my copy (now LOST!) 20 years ago.
Im not too sure, but i've read good things about this book, any opinions on getting this one? http://www.amazon.com/exec/obidos/AS...321984-9512013
............................Sorry bro
