obd0 b16 dizzy question
Old Jun 28, 2010 | 11:58 AM
StupidSlowRSX's Avatar
Default obd0 b16 dizzy question
Hey guys, quick couple question for you
im working on getting my boys car running, hes got a 91 hatch with an obd1 sirII b16a motor with cable ls trans. my questions are as follows. His car doesnt have a dizzy so I brought over my brand new obd1 dizzy, and stuck it on. Obviously, the dizzy won't plug in, the harness being obd0 and the dizzy I brought over being obd1. However, Im very handy and fimiliar with all the wires and pretty much everything. Anyway, I depinned his dizzy harness and matched it up to the obd1 dizzy. The car has spark, but won't turn on. Im using an obd0 PW0 ecu. Im guessing I can't use an obd1 dizzy on an obd0 ecu?
Also, he has an obd-0 dizzy, but it gets no spark. I've tried switching the coil and ignitor out and still got nothing. What coils and ignitors can I stick in the obd0 dizzy to get spark? Is the coil and the ignitor the only thing inside the dizzy to cause it not to have spark, aside from the rotor and cap, those are both good.
Old Jun 28, 2010 | 12:01 PM
lunalink's Avatar
Default Re: obd0 b16 dizzy question
nope it wont read it. ( far as i know )
and you cant use an obd1 dizzy with and obd0 ecu. I have a P28 if you need one chipped with the b16 base map LMK!
Old Jun 28, 2010 | 02:01 PM
lmao, no thanks, Its not my car, im just getting it going for a friend then selling it. Can anyone give me clues on the dizzy internals?
Old Jun 28, 2010 | 02:05 PM
lunalink's Avatar
im just saying.
and the ECu wont be able to read that dizzy no matter what you do. you're bet off getting an LS dizzy and cutting a Leg or just get the proper dizzy for that motor
Old Jun 28, 2010 | 04:10 PM
FOMULA91's Avatar
lunalink is correct... You cannot use OBD1 distributor on OBD0 ECU... Get another OBD0 Distributor or convert it to OBD1 using the jumper harness and OBD1 ECU...
Old Jun 28, 2010 | 04:27 PM
Ok. Whats coils and ignitors are compatable for obd0 b series?
Old Jun 28, 2010 | 05:24 PM
crx_si-r's Avatar
Any of the following coils and modules will interchange...
Td01 88-91 dx dpfi civic/crx
Td02 88-91 si or ex sedan 90-91 mpfi civic/crx
Td18 88-91 si mpfi civic/crx
Td22 Jdm b16a
Td23 90-91 b18a1
Td24 90-91 b18a1 (auto I think)
Pm me I have a spare obd0 b16 dizzy
Seto-Initial-B
Feb 14, 2008 08:06 AM
dougshatch
Jun 14, 2007 12:41 PM
crxmex
Jan 28, 2007 01:42 AM
iphatcrxi
Dec 12, 2004 04:53 PM
turbohf
Mar 28, 2004 09:09 AM
