why wont my car start?!?!?
Old Sep 14, 2002 | 02:22 PM
wu tang's Avatar
Default why wont my car start?!?!?
ok....so i used to have a d15b1 in my hatch. but the rings went bad. so i bought a d16a1. and i put my dpfi intake mani. on the d16a1. but i got everything pluged in right. and it started up the first try. so when the motor was on, it smoked really bad. an i bought some new fuel injectors, then i put those in and my car ran really good for a minute, then smoke started shooting out the the exhust and smoke was coming from the head gasket. so i putted the head off, threw the new gasket in there, and the timing was off and i started it up, i bent the vavles, so then i put on my std head. and got the timing just perfect. but now it wont even go. and i bought a new cap and rotor for it. and im getting spark.
but, right now heres what im thinking. back when i had my stock motor in. whenever i would stall my car it wouldnt start back up. it made a weird sound. and right now its making that sound. and i know that my main relay switch is bad. cause thats why it wouldnt start up. and i havent tried to get one yet. im getting one in a few hours. but i just want to hear other people options. thanks
Old Sep 14, 2002 | 05:22 PM
HF2ZC's Avatar
Default Re: why wont my car start?!?!? (wu tang)
So, the starter isn't turning? Sounds like a main relay to me too. Also check to make sure that your fuses (there are 2) for the starting system are good, and that there are no breaks in the wiring from the battery to the starter.
Old Sep 14, 2002 | 05:40 PM
Iceycrx's Avatar
Default Re: why wont my car start?!?!? (HF2ZC)
yea listen to hear the starter working, if that isnt working then u know where to go from there, sounds like everything i had wrong with my car
Old Sep 14, 2002 | 06:17 PM
wu tang's Avatar
Default Re: why wont my car start?!?!? (Iceycrx)
well i know or a fact that the starter is turning, cause i just put a new one in there, cause the old one broke. so you guys think its the main relay?? but what fuses are you talking about??
Old Sep 14, 2002 | 11:09 PM
Louie B.'s Avatar
If you're turning over, getting spark, and the spark is timmed right, than you're not getting fuel. main relay will be the first culprit, after that, check the fuel filter, followed by the fuel pump.
Old Sep 15, 2002 | 12:05 AM
shortyz's Avatar
Default Re: why wont my car start?!?!? (thumpu77)
uhm how the hell did you bend the vavles when all u were doing was putting on a new headgasket.
did you re and re the cam?
Old Sep 15, 2002 | 12:57 AM
wu tang's Avatar
Default Re: why wont my car start?!?!? (shortyz)
oh, i had th timing WAY off. like i had the timing just soooo far off. but doesnt the main relay control the fuel and stuff??
Old Sep 15, 2002 | 08:08 AM
Louie B.'s Avatar
Yes, the main relay controls the fuel pump and the fuel injectors.
deepfriedjinx
Aug 26, 2024 01:01 AM
coltonbarrier
Feb 7, 2014 04:06 PM
h22silvia
Jul 28, 2009 09:53 PM
dcomer04
May 14, 2008 07:50 AM
Galaxy Si
Apr 6, 2005 06:27 AM
